Re: Springs moved inside frame
[Re: jamesc]
#1197180
03/15/12 01:48 PM
03/15/12 01:48 PM
Posts: 4,632 Motor City
6PKRTSE
Motor City
My Challenger was done like this when I first got it. Total hack job, way over done though with 2x4" box tubing. All of the factory everything was still left intact. Knowing I was cutting it all out & going with Caltracs & just a standard relocation kit anyway it was no big deal to me to fix correctly.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#1197183
03/15/12 03:31 PM
03/15/12 03:31 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Somebody else posted pics on here before of inboarded springs inside the chassis rails but they were done in a professional manner, they also sectioned the chassis rails for more tyre clearance That is an accident waiting to happen. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: correctdirection]
#1197184
03/15/12 04:36 PM
03/15/12 04:36 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Funny everyone saying what a disaster this is, when the car runs mid 11s. And presumably the metal is not warping or the welds cracking.
Maybe the guy got lucky, or maybe his work is fine. It is working to run mid 11s after all.
Some people on these forums post pics of work done that others poo poo, and we have seen that this prevents more people from posting pictures of work that people would disagree with (that is different from "normal"). So there are more people out there doing things differently than we hear about, I guess they don't post to avoid people screaming about what a disaster their work is.
I'd like to see those people explain why this design is actually unsafe-- knowing how much weight/force is on each of the 4 involved weight-bearing areas of the rearend (the front and rear hangers on each side), and that a properly welded bracket of sufficiently sized steel would fail under those forces. We cannot actually see how the front hanger bracket is attached to the frame, so that is an unknown.
It's not hard to put new boxes in to relocate the springs into the rails if you agree it's a disaster. This alone is not a reason not to buy the car IMO.
[Re: Exit1965]
#1197187
03/15/12 10:37 PM
03/15/12 10:37 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Suspending the weight is not the problem , as you probably know. The forces from accelerating are where I get worried. The front spring mount does not appear to be all that sturdy , and that is where it will go south. Where you say it hasn't broken , I can only add " yet ". This is not cool.
[Re: Exit1965]
#1197189
03/16/12 11:54 AM
03/16/12 11:54 AM
Posts: 5,875 communist bloc of new jersey
jamesc
so that's your criteria for chassis safety? i mean those front mounts only hold the rear axle in and absorb all the driving forces. it would run mid 11s if you drove it off a cliff too that doesn't mean it's a good idea. that is a flat out mess to put it mildly. i'm not saying it should stop someone from buying the car if the price is right. the OP came here and asked for input because he had concerns (and rightly so), imho that job needs to be redone but to each his own.
[Re: Exit1965]
#1197191
03/16/12 12:18 PM
03/16/12 12:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd like to see those people explain why this design is actually unsafe-- knowing how much weight/force is on each of the 4 involved weight-bearing areas of the rearend (the front and rear hangers on each side), and that a properly welded bracket of sufficiently sized steel would fail under those forces. This design is going to have flex... being that the load is applied to 1 side... flex ends up causing cracks and failure... if its boxed with a gusset applied to the edge and running to the frame it will spread the load and keep it from flexing.... also flex adds in binding which can change all the time and makes it(the car) less consistent.... there is a magic word in chassis building... triangulation
[Re: Exit1965]
#1197192
03/16/12 12:21 PM
03/16/12 12:21 PM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
Want to IMPRESS people with that hack job ... what does it 60ft and with what type of tires ?
One can throw enough HP into anything and get it to run mid 11's with an unimpressive 60ft .
You must be connected with the builder to take such offense to the concenus of those that replied ...
