26" B-Body Radiator Shroud Mount? #1196402
03/13/12 03:02 PM
03/13/12 03:02 PM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
Hey All,
I need to buy a shroud for my 68 440 Charger but I'm confused. The standard part # P2785434 looks like this:
It has three mounting holes on one side, and two on the other.
My radiator has 4 mounting points in a square. It looks like it wants something like this:
But that pic is for a 22" shroud that requires a mounting kit.
The car was originally a 318, and had the 440 installed sometime back in the 1980's. The engine came from a '73 something, and I have no idea what the radiator is, except that it is 26" across the core.
Will the standard part # bolt up good enough even though all the holes won't match up? Or do I need something else?
Also - I was thinking about using the 30% off from YO for the shroud, which makes it $70+$30 shipping. Could I get it cheaper anywhere else?
Thanks!
Re: 26" B-Body Radiator Shroud Mount? [Re: Gusteve] #1196403
03/13/12 03:24 PM
03/13/12 03:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The top one is the proper one for your car IF it had the correct radiator, it does not. In 1970 it changed the 4 bolt design similar to the bottom photo, that is the one you want to get to put on the radiator you have .
Re: 26" B-Body Radiator Shroud Mount? [Re: JohnRR] #1196404
03/13/12 04:04 PM
03/13/12 04:04 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Thanks.
I was thinking maybe that whatever car from '73 donated the engine probably also donated the radiator.
Too bad for me the '70 up costs another $30 or so.....
Thanks again.
Edit - looks like its <$90 locally from Mancini or RosevilleMoparts.
