Page 2 of 3 1 2 3
Re: Latest W2 heads [Re: dogdays] #1196097
03/13/12 07:01 PM
03/13/12 07:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a new set of W-2 in the shop(prior to this
latest version) that I plan on porting but havent
got around to it... I also have a set on my 396 ci
thats in the P right now... I ported those also but
I didnt go all out and they flow 305 at 600... I have
just about enough parts(lacking rods) to build another
W-2 engine for something... dont know what yet
Re: Latest W2 heads [Re: ZIPPY] #1196098
03/14/12 09:23 AM
03/14/12 09:23 AM
ms
W
w2dak394 Offline
w2dak394  Offline
W
ms
Is there not an oil passage from the deck surface on the top head in picture.
Re: Latest W2 heads [Re: w2dak394] #1196099
03/14/12 10:48 AM
03/14/12 10:48 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
W2s are a great head, and if you are lucky enough to still have an old set of NORRIS rockers then you have a very solid top end for your latemodel, or street stock IMCA gm eater. I would love to have a W2 headed mopar in my buddys current street stock IMCA dirt car, but we dont have enough spare parts laying around for that unforseen failure, so he is just gonna run the GM that is supplied with the car.
Re: Latest W2 heads [Re: w2dak394] #1196100
03/14/12 11:42 AM
03/14/12 11:42 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
W2's since around the late '90s have been set up for pushrod oiling, or at least that was design intent. If I understand correctly circle track racers requested that change to be made for a long time prior.
I'm sure somebody has a set from the interim time period that are not set up that way and would debate that....I've heard of them before. As with all things Mopar: never say never...
That design does force the builder into more expensive rocker arms like TD and so on, but that style of rocker usually cures enough other potential issues it's worth the change.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196101
03/14/12 09:55 PM
03/14/12 09:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
but in his pictures of 2 new heads 1 has the hole for shaft oil the other 1 does not.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Latest W2 heads [Re: dusturbd340W5] #1196102
03/14/12 10:41 PM
03/14/12 10:41 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Aha, thanks-I see it now.
Thanks for pointing that out.
Next chance I get in the shop I will dig those heads out and see what's up.
If there were any efforts made to make them work with the old rockers (the only reason for the oil hole) then we need to know about that. Far as I know they are supposed to be TD only but maybe I am missing something.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196103
03/14/12 11:46 PM
03/14/12 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
that is weird... all the w-2s I've seen used shaft
oiling and yours have one of each
Re: Latest W2 heads [Re: ZIPPY] #1196104
03/14/12 11:51 PM
03/14/12 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those are so called w-2 race heads but even the stands
look tall... almost as tall as the econo but without
the cradle in the stands
Re: Latest W2 heads [Re: MR_P_BODY] #1196105
03/15/12 12:10 PM
03/15/12 12:10 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Any confirmation on the rockers? Will they take the old Crane gold's with the stands or is it T&D only?
Re: Latest W2 heads [Re: HardcoreB] #1196106
03/15/12 12:41 PM
03/15/12 12:41 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Haven't figured it out yet
Easiest way to get where I need to go would be to get my hands on some of the supporting parts and mock them up, but I don't have anything.
I've hoarded big block stuff forever but don't have anything for a small block
Will do some asking around.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196107
03/15/12 04:29 PM
03/15/12 04:29 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I have a set of rockers you can borrow...look me up ifin' you're ever up at CTC.
Re: Latest W2 heads [Re: HardcoreB] #1196108
03/15/12 05:49 PM
03/15/12 05:49 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Practically never go there, maybe once or twice a year tops.
But if shipping is an option, pls feel free to PM or call and I'll hook everything up
Thanks for the offer, regardless of how it works out
Did some more detective work and it appears there is a possibility one head is machined to the old spec for old rockers, but I don't have an answer for the other one.
Hopefully 4 or 5 more phone calls/emails tomorrow will get us what we need.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196109
03/15/12 06:03 PM
03/15/12 06:03 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
exhaust, pretty much what you would expect to see
i hope they dont leak like the other castings,2nd head bolt in near the w2 marking,is where they took meat away from the casting that caused leaks last time
Re: Latest W2 heads [Re: fishy340] #1196110
07/10/12 12:42 AM
07/10/12 12:42 AM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
Anymore updates or pics on these heads? I think that is the 55cc combustion chamber head you showed? Do they still make any 15 degree heads?
Howard
Re: Latest W2 heads [Re: dizuster] #1196111
07/10/12 02:04 AM
07/10/12 02:04 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
As I understand it, they are not all that much better then an Eddy head.
So as a comparison they are a little better. But heavier, use a special intake/rockers, and cost more (quick look put these in the $1100 bare range).
Not too hard to understand why not too many people run them anymore based on that.
I think more circle track guys run them because some rules force "iron heads" on the teams.
Any time you get rid of the pushrod pinch on a sbm it is gonna run better, regardless of flow #s even. I personally believe a ported w2 is gonna outperform a ported edelbrock very easily.
Re: Latest W2 heads [Re: viperblue72] #1196112
07/10/12 09:33 AM
07/10/12 09:33 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Best as I've been able to determine, the one with an oil hole was a preproduction oddball and was not really intended for public consumption. Sorry to cause any confusion by posting a pic of it....
I finally got the chance to check out some regular production newer 769s and they don't have the hole (and they're not supposed to have it, so I guess that is a good thing).
The ones pictured are the 65cc NASCAR spec, the part number ends in 769, originally intended for 59 degree lifter angle.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196113
07/10/12 03:01 PM
07/10/12 03:01 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Hi Rich...hope all is well.
Why would they do that?? Why get rid of the shaft mounted oiling?? You can always modify the oiling system and turn it into pushrod oiling BUT you can not go in the other direction. Personality I like the shaft mounted oiling for a few reasons and on a street/strip engine it is by far easier. To me it is better to give the customer many options and let them decide what direction they want to go in and not force them to do something or buy something that they already have.
I know having two part numbers could be a pain but we are talking about one hole.... one machining process...offer that head in two versions, with or without shaft mounted oiling. sorry but just my
As for the Edelbrock lovers out there.... I'm sorry but W2s are a wonderful head and yes they are iron but think about that for a minute...
Run less compression and make more power. This means a lighter piston.
Much better intake and exhaust runner design.
Out of the box better flowing on both intake and exhaust ports.
I'm well aware of the draw backs of the W2 and to me there is not that many . Cost is a big one when your going from a running engine and want to adapt over to a W2 setup. If your staring from scratch you have to buy rockers, intake and headers anyway.
If you want to keep things simple the Edelbrock heads are hard to beat and they have a place in engine building. I do think there are some better options out there and that is where W2 can be fun!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Latest W2 heads [Re: MR_P_BODY] #1196114
07/10/12 03:26 PM
07/10/12 03:26 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Terrible shot of an intake bowl. Sorry.
I gave up trying to get a good shot of the exhaust.
Filled in bowl, eh???? Is that what I'm seeing?
HAH! Brian said "eh"... You sure your not part Canadian?
They look like they have more meat in the top of the
runner so it could be moved up higher... I dont recall
the top of the runner being flush with the VC rail
Looks like it to me too. Good catch. My Econo's don't have that much casting above the runners...
-Kenny
Re: Latest W2 heads [Re: Troy] #1196115
07/10/12 03:44 PM
07/10/12 03:44 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
As the legend was passed down to me, many years ago the sportsman Nascar racers complained to Mopar to get rid of the shaft oiling, Mopar finally gave in and did it. They went on about how it was too much extra work to cut the heads for TD rockers, nobody wanted to use the old stuff anymore and why couldn't the heads be made that way to begin with. And since they are the primary customers for that 769 head, they did have a good point.
That's not to say nobody at MP likes shaft rockers...Back in '07, management was getting set for the econo head to make a comeback. There were two PN variants and they're listed in the 2007 catalog on page 88, marketed as "W2 Classic". Unfortunately they were ahead of their time: more research revealed the castings needed to be retooled, and that was the last I heard of those two new part numbers. They were only a blip in one catalog; none were ever produced in that timeframe and they come up ns7 now.
I had assumed (incorrectly) the W2 retool would be part of the huge push in '07-'08 that resulted in rework of hemi/RB wedge, LA/R3, aluminum and iron hemi heads,iron max wedge heads, the intro of the aluminum 452/straight plug rpm and stageVII/Victor and so on....but it was not in the cards. It is interesting how it worked out.
Personally I would like to see a shaft oiled W2 available but am not sure how it would sell?
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196116
07/10/12 05:40 PM
07/10/12 05:40 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
right below where it says w2 and mopar on the exhause picture,when they removed that iron around the head bolts is where you were able to take a shower from the leaks the last time they removed iron..hopefully it dont happen again
Page 2 of 3 1 2 3
