Page 3 of 3 1 2 3
Re: Latest W2 heads [Re: fishy340] #1196117
07/10/12 06:20 PM
07/10/12 06:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
right below where it says w2 and mopar on the exhause picture,when they removed that iron around the head bolts is where you were able to take a shower from the leaks the last time they removed iron..hopefully it dont happen again
I have two of those leakers too in the same spot. Its a shame to because I only did a mild port job to my set because of the small cam that I am running and they were still flowing over 310 cfm. Going back to edelbrocks now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Latest W2 heads [Re: pittsburghracer] #1196118
07/11/12 03:37 AM
07/11/12 03:37 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The set I have in the garage are closede chambers, have to check the casting and part numbers. They both have the oil holes, I have HS rockers for tehm too but haven't even trial fitted them, so don't know wether they'll fit or not.
Plynouth VIP '67 TT IC EFI
Re: Latest W2 heads [Re: jim sciortino] #1196119
07/11/12 11:03 AM
07/11/12 11:03 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Plus, with a little grinding, you can tell the brand Xers they just got drilled by an all iron 340.
Funny you mention that. That prettymuch happened with my car last year. Lined up with a procharged mustang at a street car shoot out. Before we raced, We both asked questions about each other’s cars. I told him, it was an all iron small block, with 3.23 gears, and an 8.5” slick. All true.
http://www.youtube.com/watch?v=8-PO1bCE3...ture=plpp_video
Re: Latest W2 heads [Re: StrokerAspen] #1196120
07/11/12 06:14 PM
07/11/12 06:14 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Iron heads run better then alum in a 10.0 comp motor JMO. we are going back to iron on my daughter's 340, takes forever to warm up motor, and does not run good until about 30min of driving.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Page 3 of 3 1 2 3
