Page 1 of 3 1 2 3
Latest W2 heads #1196077
03/13/12 12:15 AM
03/13/12 12:15 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
MP still makes W2 heads, seems like the primary customers are sportsman circle track racers? Though aluminum is the rage these days, I dunno....W2 heads look to be just as viable as they ever were.
Haven't been able to get any flow data yet, but these look nicer than the previous ones I have worked with.
Can't find anything ugly that I don't like in the castings, machine work looks clean and so on. Looking for differences new vs. old....if anything the castings have more of a "squared off" appearance on the outer walls of the intake ports (looks like more material?). The deck surface also appears slightly thicker to me than the last ones I had, but that's just from memory.
One thing that stand out...this is one of those oddball parts that the casting number matches the part number, which almost never happens. These are the 769s.
Anyway I got a chance to check them out and maybe you'd like to see them too.
I'm sorry my camera skills kinda suck for getting shots of the bowls...I tried, but the pics of those areas didn't turn out well.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196078
03/13/12 12:20 AM
03/13/12 12:20 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Terrible shot of an intake bowl. Sorry.
I gave up trying to get a good shot of the exhaust.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196079
03/13/12 12:22 AM
03/13/12 12:22 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
intake flange area
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196080
03/13/12 12:24 AM
03/13/12 12:24 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
exhaust, pretty much what you would expect to see
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196081
03/13/12 12:29 AM
03/13/12 12:29 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Foundry mark. Looks just like the one on a few recent engine blocks, apparently they do some nice work there.
Sorry for the lack of gory details, maybe somebody has flow tested them and can post up...I have not taken the time to ask or look, to be honest.
I mostly intended this as a "hey do you remember them?" kind of deal, and thought I would mention there are some new ones out now.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196082
03/13/12 12:29 AM
03/13/12 12:29 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Rich...were these pics taken at work? The reason I ask,is the last shot appears to be a granite inspection plate that the W-2's are sitting on. Am I correct? Thanks! Randy B. BTW...I sent you a PM about your Mopar presents! THANKS!!
Re: Latest W2 heads [Re: Labratt] #1196083
03/13/12 12:36 AM
03/13/12 12:36 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yes sir, that is indeed a granite surface plate good eye!
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196084
03/13/12 01:19 AM
03/13/12 01:19 AM
SoCal
Brian Hafliger Offline
SoCal
Filled in bowl, eh???? Is that what I'm seeing?
Brian Hafliger
Re: Latest W2 heads [Re: Brian Hafliger] #1196085
03/13/12 10:01 AM
03/13/12 10:01 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yeah, maybe slightly?
I would trust your opinion on that more than my own!
It's hard to say with any authority because I don't have the old ones around to compare them to anymore...and I'm sure not enough of an expert with them to "remember" the shape. Heck I can hardly remember what I had for lunch yesterday...
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196086
03/13/12 10:58 AM
03/13/12 10:58 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
What's the factory part number and pricing. I have a buddy that is envying mine a little too much and wants a set for his 416....Maybe this will keep him away.
Re: Latest W2 heads [Re: Dragula] #1196087
03/13/12 11:12 AM
03/13/12 11:12 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
P5249769 the price is 656 retail, and there looks to be
94 of them available in the depot system.
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196088
03/13/12 12:22 PM
03/13/12 12:22 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
It has been years since we worked with W2s. There were three different valve angle that could be obtained. The 18 degree heads were good, used standard W2 rockers and worked with either a 59 or 48 degree block, flowed about 250 CFM @ .700", the 15 degree heads were better---could flow up to 290 @ .700" if "prepped" properly---but required a 48 degree block and special "oil through pushrod" rockers(Jessel). There were a few sets of 12 degree heads---primarily through Stanton that were real good but required T&D rockers.
Re: Latest W2 heads [Re: 40ford] #1196089
03/13/12 12:35 PM
03/13/12 12:35 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I just recently obtained a set for my nostalgia project..
http://kuvablogi.com/nayta/3397443/
Plynouth VIP '67 TT IC EFI
Re: Latest W2 heads [Re: jyrki] #1196090
03/13/12 02:21 PM
03/13/12 02:21 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
As I understand it, they are not all that much better then an Eddy head.
So as a comparison they are a little better. But heavier, use a special intake/rockers, and cost more (quick look put these in the $1100 bare range).
Not too hard to understand why not too many people run them anymore based on that.
I think more circle track guys run them because some rules force "iron heads" on the teams.
Re: Latest W2 heads [Re: dizuster] #1196091
03/13/12 02:49 PM
03/13/12 02:49 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
The Eddys are a nice, affordable street/mild performance head, but I would run a W-2 over the Eddy in a race effort where cost is not a factor.
I've seen W-2s go 320+ with good air speed and a 15* closed chamber W-2 on a 48* block is no contest, especially if the right guy does the port, chamber and intake work.
Plus, with a little grinding, you can tell the brand Xers they just got drilled by an all iron 340.
Re: Latest W2 heads [Re: jim sciortino] #1196092
03/13/12 03:29 PM
03/13/12 03:29 PM
X2
+300cfm, they are the best head for the money...
Re: Latest W2 heads [Re: ZIPPY] #1196093
03/13/12 03:57 PM
03/13/12 03:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They look like they have more meat in the top of the
runner so it could be moved up higher... I dont recall
the top of the runner being flush with the VC rail
Re: Latest W2 heads [Re: MR_P_BODY] #1196094
03/13/12 05:32 PM
03/13/12 05:32 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Mike I was thinking about that last night and could not really remember, so that's good input.
It seems like they have alot more meat on the sides too,
The outside of the intake runners sort of looks like a box or a rectangle, with corners slightly rounded off....more boxy looking than the older ones for sure
Rich H.
Esse Quam Videri
Re: Latest W2 heads [Re: ZIPPY] #1196095
03/13/12 05:56 PM
03/13/12 05:56 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
zippy this is good news,thanks for the heads up on them!
im getting a serious case of W-head envy,whatever my next build will be W2īs are absolutely at the top of my want to get list.
Re: Latest W2 heads [Re: 1Fast340] #1196096
03/13/12 06:50 PM
03/13/12 06:50 PM
dogdays Offline
dogdays  Offline
When the W2 first came out it was said that it outflowed every factory head in production at the time. That's hot.
There have been many improvements over the years, combustion chamber being the best change IMHO.
Prices seem high until you start comparing bare for bare with aftermarket cast iron race heads for the smallblock chevy crowd, then they don't look so bad. Cast iron heads aren't so much cheaper any more.
R.
Page 1 of 3 1 2 3
