Which mufflers flow the best? #1194902
03/11/12 02:50 AM
03/11/12 02:50 AM
Texas
bogusracer Offline OP
Texas
Looking at getting mufflers for my Cuda. Wanted to know if the Dynomax Ultra Flow SS Polished mufflers flow better than the Magna Flow SS mufflers? Trying to get the best performing muffler I can and still look relatively stock. Exhaust pipe diameter is 2.5"
Thanks for your input in advance.
Bogusracer
Re: Which mufflers flow the best? [Re: bogusracer] #1194903
03/11/12 02:55 AM
03/11/12 02:55 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This question was asked a few months back, and a helpful member posted a sheet of the top selling mufflers and how they fared against each other. The Dynomax welded Ultra Flow mufflers were tops.
Re: Which mufflers flow the best? [Re: Kern Dog] #1194904
03/11/12 03:16 AM
03/11/12 03:16 AM
Texas
Texas
Not looking at the welded Ultra Flows. The polished stainless steel are constructed like the oem type mufflers. Those are the type I'm looking at. Any comparisons between those and the Magna Flows?
Thanks,
Bogusracer
Re: Which mufflers flow the best? [Re: bogusracer] #1194905
03/11/12 10:42 AM
03/11/12 10:42 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Bogus, the 2.5" st. st UltraFlos have a slightly larger internal pass tube and outflowed the equivalent sized Magnaflow by a few percent when comparing airflow directly through them.
Tom
Re: Which mufflers flow the best? [Re: Tom Hand] #1194906
03/11/12 09:50 PM
03/11/12 09:50 PM
Texas
Texas
Thanks for the info Tom. I appreciate it.
Re: Which mufflers flow the best? [Re: bogusracer] #1194907
03/11/12 10:38 PM
03/11/12 10:38 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You can look at Jones mufflers. Tim
Re: Which mufflers flow the best? [Re: astjp2] #1194908
03/11/12 11:09 PM
03/11/12 11:09 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Nope - Jones doesn't have anything like the Ultra Flows. The SS Ultra Flows have the spun-locked heads & they are straight through & NOTHING on the market will flow a higher cfm flow rate.
Re: Which mufflers flow the best? [Re: Sunroofcuda] #1194909
03/11/12 11:22 PM
03/11/12 11:22 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Yup.
The walker guys at MATS a few years ago said theirs were the only TRUE zero loss muffler.
That's a what they said...(three dots, no more)
Re: Which mufflers flow the best? [Re: Sixgun] #1194910
03/12/12 12:54 AM
03/12/12 12:54 AM
Yup.
Do you believe the marketing types? I don't Test and tune to see what results you get I have a set of the older Magnaflow 14x7 inch ovals 3 inch side inlet with 3 inch center outlet on my car, it ran .03 to .04 (3 hundreds to 4 hundreds) slower in th 1/8 mile with the complete exhaust sytem on, the muffs are mounted at the rear bumper behind the rear end, and .1 to .2 MPH different. The car ran a best of 7.01 with the sytem on and a best of 6.97 with it off the weight was probally most of the gain, not the back pressure
Re: Which mufflers flow the best? [Re: Cab_Burge] #1194911
03/12/12 07:14 PM
03/12/12 07:14 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
both mufflers work well,not a big diff either way. [i own a muffler shop]go with the best deal money wise and the muff's will take of themselves.
Re: Which mufflers flow the best? [Re: Cab_Burge] #1194912
03/12/12 07:29 PM
03/12/12 07:29 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Magnaflows are cheaper knock-offs of the Dynomax welded series Race Magnums. They are straight-through. I've heard lots of complaints of Magnaflows droning really bad, sounding too quiet & "flat", & also read complaints of the outer skins splitting open from fatigue.
Re: Which mufflers flow the best? [Re: Sunroofcuda] #1194913
03/12/12 10:45 PM
03/12/12 10:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I noticed alot of FAST racers use the Ultra-Flows so thats why I looked at them and liked them. So I use the Ultra-Flows with a 3" X-pipe system out to the rear bumper. I always race thru the pipes as I never uncap it so I really dont know if it slows the car any. Ron
Re: Which mufflers flow the best? [Re: 383man] #1194914
03/12/12 11:53 PM
03/12/12 11:53 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Just for the sake of discussion-
Last time I looked at mufflers, I noticed that the box, I think Dynomax, said they flowed either 500-700 CFM.
So if you have two mufflers, does it really make any difference if you are running a 650-800 CFM carb?
I want my fair share
Re: Which mufflers flow the best? [Re: Sunroofcuda] #1194915
03/13/12 08:47 AM
03/13/12 08:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
ever flow your own mufflers to see how they do?
**Photobucket sucks**
Re: Which mufflers flow the best? [Re: 70Cuda383] #1194916
03/13/12 09:26 AM
03/13/12 09:26 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
