Throttle linkage stud help needed....Holley #1194155
03/09/12 08:26 PM
03/09/12 08:26 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am running a Holley 770 Ultra Street Avenger on my 440 with a Edelbrock RPM intake and the AR engineering throttle bracket that uses the OEM Kick down linkage ( I know not the correct term)and throttle cable. AR's bracket raises everything to compenaste for the higher Intake...Anyway I need to know what Throttle Linkage stud I need to hook everything up without getting all complicated...
Anyone help me out??
Re: Throttle linkage stud help needed....Holley [Re: moparrulzzz] #1194156
03/09/12 08:43 PM
03/09/12 08:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does that Holley have the #20-7 Mopar Throttle Lever Extension?
Re: Throttle linkage stud help needed....Holley [Re: John_Kunkel] #1194157
03/09/12 08:47 PM
03/09/12 08:47 PM
Mansfield,Ohio
Mansfield,Ohio
Yes , forgot to add that info. I bought it seperately, totally wasnt thinking about the stud to attach everything!!
Re: Throttle linkage stud help needed....Holley [Re: moparrulzzz] #1194158
03/09/12 09:01 PM
03/09/12 09:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you don't need that. You can inlarge the middle hole a tad and fit the stock piece right thru it. I think I have one of those brackets if you really want one.
Coming soon!!!!
Re: Throttle linkage stud help needed....Holley [Re: Mr.Yuck] #1194159
03/09/12 09:38 PM
03/09/12 09:38 PM
Washington state, USA
vandude Offline
vandude  Offline
If you are talking about one of these (attached to 20-7 bracket):
you can grab one off any 70's Dodge 2-bbl-equipped V8 trucks or vans.
It works fine on my '77 Tradesman (with mildly-modified stock linkage and RPM/Holley intake combo)
Re: Throttle linkage stud help needed....Holley [Re: moparrulzzz] #1194160
03/09/12 11:21 PM
03/09/12 11:21 PM
AndyF Offline
AndyF  Offline
Use the stock stud. They are getting harder to find in the wrecking yards so you might need to buy a reproduction throttle stud. Hoffman's Winners Circle has the entire line of Mopar throttle studs and Hoffman's sells to a ton of Mopar vendors. So you can buy that part most anywhere.
Re: Throttle linkage stud help needed....Holley [Re: AndyF] #1194161
03/09/12 11:25 PM
03/09/12 11:25 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx Guys!!! I will look for a a stock one Andy!
Re: Throttle linkage stud help needed....Holley [Re: moparrulzzz] #1194162
03/10/12 05:53 PM
03/10/12 05:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This page shows the various studs and what they fit:
http://www.hoffmanswinnerscircle.com/cat08.htm
Re: Throttle linkage stud help needed....Holley [Re: Mr.Yuck] #1194163
03/10/12 06:06 PM
03/10/12 06:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No , he needs it along with the correct stud pictured above if he is going to use the stock throttle pressure linkage .
Re: Throttle linkage stud help needed....Holley [Re: JohnRR] #1194164
06/13/14 03:26 PM
06/13/14 03:26 PM
colorado
68charger440strk Offline
colorado
Sorry to jump someone else's thread, but since it perfectly describes my situation and is no longer an active thread I thought it would be ok to tag along rather than re-describing everything in this thread.
I can't see a problem with following the advice to just drill the hole larger, making it so that the stock stud will fit. I have been studying my 870 street avenger sitting on my Eddy performer RPM intake and can't see anything that will be at an awkward angle or any other problems with doing that. What am I missing?
Re: Throttle linkage stud help needed....Holley [Re: AndyF] #1194165
06/13/14 04:50 PM
06/13/14 04:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
On my Dominator I just used the 2 piece setup that fills the large hole.Then used an OE stud.I run a 4 speed so no kick down.IIRC I used pretty much the same om my Ram Charger with kick down.Rocky
Chrysler Firepower
Re: Throttle linkage stud help needed....Holley [Re: therocks] #1194166
06/15/14 08:22 PM
06/15/14 08:22 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
20.00
