BB lifter strange #1191246
03/04/12 08:53 PM
03/04/12 08:53 PM
Warner Robins, Georgia
DusterMan Offline OP
super street
super street
Pulled a cam out of my 383 to install a stock cam. Everything looked great except for this one lifter
outside surface. Tha block is good and slick. I have never
seen this in 40 yrs of messing with engines. What you
think? these marks are all the way around and are evenly
spaced like they were made in it. The lifter turned good
in the block and the lobe surface and cam look great.
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: BB lifter strange [Re: DusterMan] #1191247
03/04/12 09:02 PM
03/04/12 09:02 PM
Looks like the marks from a burr in the lifter bore oil galley area Please let us know what you find
Re: BB lifter strange [Re: Cab_Burge] #1191248
03/04/12 09:27 PM
03/04/12 09:27 PM
super street
super street
No burr. Lifter bore are good. The marks on the top and
bottom are perfectly lined up with each other. Almost
like it was made that way. A burr would not be a perfect
strait mark. ?? Got me.
Pete:
2019 Dodge Charger
Re: BB lifter strange [Re: DusterMan] #1191249
03/04/12 10:26 PM
03/04/12 10:26 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Is the lifter covered in chatter marks from grinding?
Alan Jones
Re: BB lifter strange [Re: LA360] #1191250
03/04/12 10:29 PM
03/04/12 10:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that's the first thing I thought.
Re: BB lifter strange [Re: dartman366] #1191251
03/04/12 11:17 PM
03/04/12 11:17 PM
super street
super street
That's what I was thinking. It was made like that with high spots. They are smooth as glass. Evenly spaced and lined up top to bottom.
Pete:
2019 Dodge Charger
Re: BB lifter strange [Re: DusterMan] #1191252
03/05/12 01:08 AM
03/05/12 01:08 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
now they are
i can't see any way that pattern could be produced in the engine that had to be there when they were installed and may not have been readily noticeable
Re: BB lifter strange [Re: jamesc] #1191253
03/05/12 07:40 AM
03/05/12 07:40 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
How much running clearance does the lifter have in the bore? I'm thinking you've got a little more clearance than you need. Mopar did send some blocks out with oversize lifter bores, it's supposed to be stamped on the pad on the front of the motor. Dave
Re: BB lifter strange [Re: DusterMan] #1191254
03/05/12 11:37 AM
03/05/12 11:37 AM
NC
440Jim Offline
440Jim  Offline
NC
Although it doesn't seem to have caused any problem (yet);
when you catch something like that, it should be replaced after checking for any cause that might need correcting.
Re: BB lifter strange [Re: 440Jim] #1191255
03/05/12 11:53 AM
03/05/12 11:53 AM
super street
super street
Well it fit the lifter bore fine. I checked it in a couple
of others places and it fits the same. Mic the dia of the lifter
and it measures the same as the good ones. Measured the lobe lift
and it was the same as the other lobes .341. Weird!! I owned the car
for 5 yrs and the one I got it from drove it everywhere. Nothing is hurt just weird looking.
Pete:
2019 Dodge Charger
Re: BB lifter strange [Re: DusterMan] #1191256
03/05/12 12:13 PM
03/05/12 12:13 PM
jamesc Offline
jamesc  Offline
i can't see any way running in the engine could produce such a symmetrical pattern but i guess stranger things have happened. a lifter should be turning (to a point) and stroking in the bore which i just can't see producing such well spaced straight marks. i would think there were imperfections when it was made and running it polished the high spots.
Re: BB lifter strange [Re: jamesc] #1191257
03/05/12 12:29 PM
03/05/12 12:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I go back to my origional thought,,grinder chatter on the lifter I bet if you were to measure from high to low you wouldn't see .00001 difference in size.
Re: BB lifter strange [Re: dartman366] #1191258
07/23/13 02:22 AM
07/23/13 02:22 AM
BeavisHQV Offline
BeavisHQV  Offline
Hi,
did someone figured out what happened there? Have the same problem on only one lifter. Driverside, 3. cylinder exhaust valve.... exact similiar marks on the lifter as shown on his picture.
