Page 2 of 3 1 2 3
Re: Bad Main bearing cause? [Re: 340duster340] #1191176
03/05/12 12:06 AM
03/05/12 12:06 AM
Oklahoma
V
VoodooCLD Offline OP
V
Oklahoma
Ya, i don't really understand. The motor ran like hell before it threw the water pump. I almost buttoned it back up, but decided i wanted to lift the crank to properly install the rear main seal. It had good oil pressure, and didnt knock or anything. I guess i'll have to see if the line hone or crank is out of wack. What does a shop usually charge to check a crank, and line bore? I'm in stillwater, oklahoma if that helps.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191177
03/05/12 12:58 AM
03/05/12 12:58 AM
Does the motor rotate over easy? If so the rings are probally sealing, even after sitting since driven the last time. Pull the heads and take a look at the cylinder walls and pistons and rings If they look good to you it means you will need to make a decision, run it or rebuild it
Re: Bad Main bearing cause? [Re: Cab_Burge] #1191178
03/05/12 11:30 AM
03/05/12 11:30 AM
Oklahoma
V
V
Oklahoma
Ya i had the heads off last week and the cylinders look fine. The engine turnes over smooth without and grinding.I'm trying to decide what to do as of now. I'm considering doing a *cheap rebuild* by cleaning it my self. having the line bore checked,bores checked, turning the crank next size, and putting in new main and rod bearings. I'm also considering keeping my eyes open for a 383 or 440 short block that's ready to run, and reusing my 906 heads. The more i think about it, the more i wanna blame poor oiling for this.
Anyone got a fresh short block for sale?
Oh ya, I've decided I'm definitely gonna bring my crank to a machinist to have him check it out. The condition of the crank will definitely determine my final approach.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191179
03/05/12 11:34 AM
03/05/12 11:34 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd say the motor was assembled very dirty from the looks of those bearings. Time for a new crank if your old one is already .010" undersize.
Re: Bad Main bearing cause? [Re: Challenger 1] #1191180
03/05/12 12:27 PM
03/05/12 12:27 PM
Oklahoma
V
V
Oklahoma
Why time for a new crank? They make bearings to .040 under.
Re: Bad Main bearing cause? [Re: Challenger 1] #1191181
03/05/12 12:29 PM
03/05/12 12:29 PM
dogdays Offline
dogdays  Offline
Since when did a 383 crank have inherent weaknesses that made it unusable if it had been ground more than 10 under? NEVER.
There are main and rod bearings out to at least 40 under. Racers looking for that last hundredth or two often used to grind the cranks down as much as they could get bearings to fit. The popular 3.91" stroke offset ground 440 crank, or any bigblock chevy rod stroker, has rod journals 0.175" smaller than stock.
I'd say that if your main bearings look that bad, the crank needs to be reground. Period.
And with that amount of bearing material circulating I'd say you need to take the engine down and clean out all the oil passages and everything else you can clean. You can check the taper in the cylinders and the piston fit at the same time. Don't buy any new parts, including the crank regrind, until you know what you have.
Looks to me like the engine was starving for oil. The oil pump is on the front of this engine.
The progressively worsening damage from the front of the engine to the back suggests that for whatever reason there was not enough volume of oil being pumped or else there was oil bleeding out of the system before it could get to the back of the engine.
R.
Re: Bad Main bearing cause? [Re: dogdays] #1191182
03/05/12 12:39 PM
03/05/12 12:39 PM
Oklahoma
V
V
Oklahoma
R.
As much as i don't want it to be true, i think you are correct. I'm definitely gonna get the crank checked first and foremost. Also gonna be looking for a ready to go 440 shortblock, or a good builder.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191183
03/05/12 12:51 PM
03/05/12 12:51 PM
beedees Offline
beedees  Offline
Either those are full-groove bearings or the uppers are installed in the lower and vice-versa. Looking again, I see they are the lowers and are f.g. brngs, looks to be excessive oil clearnce. Maybe .010 brngs. on a .o2o under shaft? I've seen it before.
Re: Bad Main bearing cause? [Re: beedees] #1191184
03/05/12 04:33 PM
03/05/12 04:33 PM
Oklahoma
V
V
Oklahoma
Well i called a local machine shop. They charge $55 to cut the main bearings, and $110 to do the whole crankshaft. I'm gonna tear it all the way apart tonight, and inspect, and drop it off tomorrow to have them see if its salvageable.
Thanks for the help. I'll keep you updated.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191185
03/05/12 04:42 PM
03/05/12 04:42 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
My 360 engine out of my Duster looked just like that or even a little wrose-main cause was shifting @ 7500 rpm on over 200 runs down the 1/4 mile. What really did it in was spinning it to 8500 rpm doing a burn out when my I forgot to put a chip in the rev limiter
Switched to the dark side...
Re: Bad Main bearing cause? [Re: JSR1485] #1191186
03/05/12 09:21 PM
03/05/12 09:21 PM
Oklahoma
V
V
Oklahoma
Well i got the crank out. Looks like the mains are possibly just .001 under what there supposd to be. The rod bearings were nowhere near as bad as the mains, but i could see some copper in places. I did find some metal shards in the oil pickup, but i'm not sure where they came from. I saw a few different spots on the crank that looks rather rough, and wonder if they maybee came off it. Here is a picture of a spot that looks rather shady. Its tough to tell but thats a metal curly cue, and i was able to break the top off with just my fingers.
I found a Steel crank 440, and might end up building that, but man are rods and pistons expensive.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191187
03/15/12 12:34 AM
03/15/12 12:34 AM
Oklahoma
V
V
Oklahoma
Ok so for an update, i stripped the entire motor down and noticed that there was a chunk taken out of one of the cam lobes. I'm sure the engine was dirty however i have a strong feeling that the oiling was a problem for the bearing failure. I noticed that i have a m63hp which is a melling high PRESSURE pump. Could this have been the cause of my rear main seal leak all along?
As for the bearing failure, it had that high pressure pump, no windage tray, and an el cheapo stock oil pan with baffling. Also i noticed the pickup tube measure like .6" or something, and the inlet was .56". Is this the measurements of the hemi oil pickup? I thought 383's had the smaller pickup tube. Did someone drill and tap out the oil pickup (if they did, they did a pretty good job)?
Can anyone determine if this oil set up could have been the cause of my bad main bearings? I looked around and it seems not too many people run the high pressure pumps. whats the deal with them on a semi hot street motor?
I dont remember what oil pressure it was running at, but its a 383 bored .40 over, pretty stock bottom end with speed demon 750 carb, holly street dominator intake, headman long tube headers, and full 2.5" exhaust. Yes i ran it very hard on the street.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191188
03/15/12 03:16 AM
03/15/12 03:16 AM
3/8 National pipe thread,NPT, is the stock oil pump size on the 361 to 440, 1/2 inch NPT is stock for the M.W.426 and the 426 Street and race hemi motors. Not sure of the O.D. on either, sorry Take the pump apart and look at the gear and rotor, if not tore up you can reuse it , cut 1 to 2 coils off of the high pressure spring and reuse it, if you want more pressure after trimming the spring get some very small flat washers that will fit ino the bypass plug that holds the bypass valve and spring in the oil pump cover and install them one at a time until you get the oil pressure you want Always check it(pressure) with hot oil, not cold oil, at idle and wound out
Re: Bad Main bearing cause? [Re: Cab_Burge] #1191189
03/15/12 07:13 AM
03/15/12 07:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
3/8" pipe is 0.675" OD.
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191190
03/15/12 12:18 PM
03/15/12 12:18 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Looks like the bearings get worse toward the rear of the engine. Did you ever throw a lifter from the lifter bores? This would cause a loss of oil pressure and would cause the bearings at the rear to sustain more damage than the front as they are oiled from the front to the rear. Also by the looks of the front bearing the line bore is out and needs corrected before building it again.
Re: Bad Main bearing cause? [Re: GODSCOUNTRY340] #1191191
03/15/12 12:38 PM
03/15/12 12:38 PM
Oklahoma
V
V
Oklahoma
I don't think i threw a lifter at any point. Do you think maybe the line bore is screwed up due to the previous owner not replacing the main caps back in their original spot?
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191192
03/15/12 01:20 PM
03/15/12 01:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You don't want a 63HP they will put out huge pressure 140 + you want a 63HV gives volume at way less pressure.
Think the Hp is for industrial motors like water pumps that run 24/7 at 4000 rpm. with a canaster style filter.
took one off a friends 440 would blow the filters up and off sometimes and buried the 140 oil pressure gauge. Sharp pump gears as opposed to the rounded ones
Re: Bad Main bearing cause? [Re: Dodgem] #1191193
03/15/12 01:59 PM
03/15/12 01:59 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Interesting , just did a build with a 63HP and didn't experience any of this .
Re: Bad Main bearing cause? [Re: VoodooCLD] #1191194
03/15/12 02:26 PM
03/15/12 02:26 PM
ABSOLUTELY- The main caps have to be installed in their original position. They're line bored from the factory with the caps installed in their respective mains and can NOT be mixed.
Re: Bad Main bearing cause? [Re: GODSCOUNTRY340] #1191195
03/15/12 02:57 PM
03/15/12 02:57 PM
Oklahoma
V
V
Oklahoma
Right, i understand this. I was just wondering if the wear patterns indicate this could have been the problem, since i didn't build the motor.
Page 2 of 3 1 2 3
