A to B-Body Conversion Master Cylinder ?
#1190843
03/04/12 10:21 AM
03/04/12 10:21 AM
Posts: 2,655 western PA
mopar4ya
western PA
Looked through the tech archives but couldn't find the answer, so I'll ask it here. Have a friend doing a disc brake swap on a 66 Belvedere that is a drum brake, single line master cylinder. He has all the disc parts off of a 1974 Dart, including the proportioning valve. Trying to find out what master cylinder I need to order that will work. His car does not have power brakes. Will he need to find a different brake rod, or will his work if we get the right master cylinder? Thanks Dan ![](/ubbthreads/images/graemlins/beer.gif)
Re: A to B-Body Conversion Master Cylinder ?
[Re: mopar4ya]
#1190845
03/04/12 10:58 AM
03/04/12 10:58 AM
moparpollack
Lil Herman
Lil Herman
85086
Order a modern master cylinder and don't look back. Dr. Diff sells them with the adapter. The pushrod from a a body manual brake car are spot on for these master cylinders.
[Re: moparpollack]
#1190846
03/04/12 11:54 AM
03/04/12 11:54 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Get a master for 69 or 70 C body dick brake car.They are all I use.My 65 B with A body disc has been on for 12 years and stops great.My kids 62 300 runs the same and its also 12 years but his is drum drum power.Mine are non power.Rocky
Chrysler Firepower
[Re: moparpollack]
#1190847
03/04/12 09:44 PM
03/04/12 09:44 PM
mopar4ya
western PA
The guy is wanting to keep a stock looking cylinder if possible, and does not want to use the adapter.
[Re: therocks]
#1190848
03/04/12 09:51 PM
03/04/12 09:51 PM
mopar4ya
western PA
Did they offer a manual disc brake on a 69 or 70 C-Body? What are you using for a brake rod, or are you modifying one.
[Re: mopar4ya]
#1190849
03/04/12 11:00 PM
03/04/12 11:00 PM
moparpollack
Lil Herman
Lil Herman
85086
Thanks Dan
He will when the old style leaks out brake fluid. DAMHIK!
The new ones are more expensive but hey it's only brakes right. ![](/ubbthreads/images/graemlins/shruggy.gif)
