Page 4 of 4 1 2 3 4
Re: 11/16 tie rod upgrade, what are the benefits? [Re: autoxcuda] #3131250
03/21/23 09:17 PM
03/21/23 09:17 PM
IMGTX Offline
IMGTX  Offline
I see a lot of valid points on these but I have to wonder if Chrysler did it on the big cars, could it just be so they wear less and last longer.
Seems like if you are selling an expensive luxury vehicle you don't' want them to wear out too soon.
As for the small vette tie rods maybe they were looking at reducing the weight to get better suspension reaction. They obviously did the math so they wouldn't break too easy. shruggy
Re: 11/16 tie rod upgrade, what are the benefits? [Re: IMGTX] #3131371
03/22/23 10:26 AM
03/22/23 10:26 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The only real wear spot would be the ball and socket, are those any different in size compared to the smaller diameter ones?
Re: 11/16 tie rod upgrade, what are the benefits? [Re: Sniper] #3131838
03/24/23 02:43 AM
03/24/23 02:43 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No. Same ball and socket.
The diameter of the solid male threaded part of the 11/16" tie rod is thicker. But IMHO the hollow rolled adjuster with open slot is weaker than the Tie Rods.
Re: 11/16 tie rod upgrade, what are the benefits? [Re: autoxcuda] #3131843
03/24/23 07:08 AM
03/24/23 07:08 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
True, I imagine the best bang for your buck would be a solid adjuster rather than up-sizing to 11/16"
The adjusters in my 51 Plymouth are a solid tube, not rolled, from the factory.
Page 4 of 4 1 2 3 4
