70 Challenger door rattle/noise etc #1190212
03/03/12 12:41 PM
03/03/12 12:41 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
When I close my door I hear rattles. Sounds like a couple of screws loose in a soup can.
I have replaced all the plastic window guides/parts and adjusted the glass properly. The glass isn't the problem.
The rattles are from the inside door handle mechanism and the 2 rods going over to the latch mechanism, these 2 rods make noise at the ends where the plastic clips attach.
- What can be done to take up the sloppiness of the handle mechanism?
- Is there something that is suppose to keep tension on the rods so they don't rattle?
- How should I install Hushmat (Dynamat etc.) to give my door more of a thud sound when closing? To the door skin or behind the plastic door panel?
Any experienced advice is much appreciated!
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190213
03/03/12 01:16 PM
03/03/12 01:16 PM
Indiana
RagtopChallenger Offline
Indiana
I've owned my convertible since '71 and my doors have rattled since day one. Combine that with orange peeled paint and ill fitting panels they were really shoddy! BUT! Fast as hell!
Sorry I was not much help here.....
Rusty
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190214
03/03/12 06:22 PM
03/03/12 06:22 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
Thanks Rusty.........I guess.
I'm determined to quiet down these doors!
I got new Metro door panels and they look good and fit like a glove. You would swear they are NOS.
Any one else ?????
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190215
03/03/12 06:50 PM
03/03/12 06:50 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I disagree I have 2 Challengers that I regularly drive and neither one has door rattles. The stock rods frequently had a cloth covering to prevent them from rattling.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190216
03/03/12 06:52 PM
03/03/12 06:52 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I was going to say...it is a Challenger, of course the doors rattle.
But since thats been covered I would try putting some sound deadener in the doors. I know its going to add weight but its also going to quiet them down. I assume you will be sure to look for loose hardware if you havent already.
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190217
03/03/12 07:30 PM
03/03/12 07:30 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
Yes I have checked for loose hardware, only the rods and the inside handle mechanism are loose.
The rods have their cloth on them but they don't touch anything so they are free to rattle. Are those rods suppose to be clamped in somehow??
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190218
03/03/12 08:05 PM
03/03/12 08:05 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
I think there is a black clip if memory serves me correctly.
Sort of like the ones for the remote mirrors holding the wire from rubbing.
Re: 70 Challenger door rattle/noise etc [Re: HemiRick] #1190219
03/03/12 08:15 PM
03/03/12 08:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You must own those 2 Challengers that didn't get recalled by the factory, to install rattlers in the doors
Seriously though every E body 70-74 that I've owned rattled,...SOMEWHERE!, one of the quirks of an E body but great cars none the less
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190220
03/04/12 12:41 PM
03/04/12 12:41 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
.........You can get new cloth covering (Dynamic Renovation))...OR just put a piece of vac hose over them so they dont rattle against the metal cover or door frame. Sometimes a new plastic clip will tighten up the ends.
Re: 70 Challenger door rattle/noise etc [Re: THESHAKERPROJECT] #1190221
03/04/12 02:39 PM
03/04/12 02:39 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Remote mirror cables flapping around?
I think there's a clip to hold the cables on the mirror mounting screws. When you take the mirror off that clips falls to the bottom of the door.
Try cloth taping the cables.
Mo' Farts
Moderated by "tbagger".
Re: 70 Challenger door rattle/noise etc [Re: Grizzly] #1190222
03/04/12 10:31 PM
03/04/12 10:31 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
No that clip holds the cable out of the way. I have seen on quite a few doors.
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190223
03/07/12 11:05 PM
03/07/12 11:05 PM
USA
CHALLENGERN96 Offline
USA
My doors have never rattled and i have had my challenger for 40 years try some compressed air and blow them out
Re: 70 Challenger door rattle/noise etc [Re: CHALLENGERN96] #1190224
03/08/12 06:03 PM
03/08/12 06:03 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
The noise is only when the door is closed.
The primary noise seems to be the rods. They have the cloth sleeves on them. Are the rods suppose to be clamped some way or do they just hang there. Mine just hang there, they don't touch anything except at the ends of course and when I reach in and gently slap them in the middle you hear a rattle/metallic noise from the ends. I have new plastic clips on the ends.
The inside of the doors are clean. The remote mirror is properly secured. All glass plastic hardware is new.
Is there suppose to be anything securing the 2 horizontal rods in the middle area of them?
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190225
03/09/12 03:50 PM
03/09/12 03:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The rods go against the door shell and theres a piece that has a partial window track slider... no idea what to call it. But the rods fit between this piece and the shell tightly.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 Challenger door rattle/noise etc [Re: Silver70] #1190226
03/09/12 04:33 PM
03/09/12 04:33 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
Also look for pieces of broken safety glass laying in the bottom. I had several, I guess the previous owners broke window at least once.
Re: 70 Challenger door rattle/noise etc [Re: Silver70] #1190227
03/09/12 06:08 PM
03/09/12 06:08 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
I know what you are talking about, a galvanized plate kinda piece bolted to the window side of the inner door shell?
thanks.......that sounds like the winner!!
Re: 70 Challenger door rattle/noise etc [Re: 1970A66] #1190228
03/09/12 07:25 PM
03/09/12 07:25 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Yep, theres an opening cut in the door and the rods will show right there between the shell and that piece. Hope that does it
