Does it blow when you use the switch, as soon as you put the fuse in, or during some other change (turning the wheel, bumps, other accessories on?
Normally, blowing a fuse means the circuit is shorted to ground somewhere. Adding resistance (bad connection) will cause the lights to flash slower, not blow the fuse.
Try removing all bulbs (inspect the sockets), and try again. If it still blows, it's the wiring or switch. If it doesn't install the bulbs one at a time, checking each time. This should help narrow down the circuit. You can also disconnect sub-harnesses.
