Page 2 of 4 1 2 3 4
Re: wiped a lobe... expensive lesson [Re: JohnRR] #1188064
03/01/12 01:08 AM
03/01/12 01:08 AM
Space Station #5
471Magnum Offline OP
Space Station #5
Pulled the 2 and 4 main caps. Bearing halves looked pretty much like JohnRR's pic above. Maybe not quite as bad, but definitely scored.
No scoring on the crank though from what I've seen this far.
Guess the motor is coming out.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: wiped a lobe... expensive lesson [Re: JohnRR] #1188065
03/01/12 02:24 AM
03/01/12 02:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It's the cam , XE have fast ramps and the valves tend to slam shut.
I meant to write this very thing! Forgive me John, I'm starting to emulate your way of thinking!
Summit warrantied the first cam when it went bad. After the second one crapped out, I felt that I was pushing my luck so I just let it slide. I slipped back in a cam referred as THE Dinosaur.... the Mopar Performance 292/509. In the time since, Comp began offering that hardening process for their product line. I agree that a Hydraulic roller cam would be a better choice in terms of reliability, but the cost is just too hard to take! I'd have to sell a few parts or scrap a few cars to feel okay about spending $1000 for a cam swap!
Re: wiped a lobe... expensive lesson [Re: JohnRR] #1188066
03/01/12 02:38 AM
03/01/12 02:38 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I don't necessarily think it's the cam that's noisy, but the lifters that come with the kits. I'll be ordering a set of Topline Hylifts for the next cam.
I think my MM lobe solid might have been too much for the street.
Re: wiped a lobe... expensive lesson [Re: JohnRR] #1188067
03/01/12 09:57 AM
03/01/12 09:57 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Thats correct and creates,and resonates the noise.
Johnson Hylift manufactures lifters for many companies, At Radiac Abrasive we make grinding wheels for them.
logan426
Re: wiped a lobe... expensive lesson [Re: 471Magnum] #1188068
03/01/12 10:25 AM
03/01/12 10:25 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I wonder if the composite lifters available through 4secondsflat would be worth considering?
Re: wiped a lobe... expensive lesson [Re: MLR426] #1188069
03/01/12 10:32 AM
03/01/12 10:32 AM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
How old it the set up? The reason I ask is there was a run of "bad" lifters going around a few years ago. Too bad you got bit, there is far too many variables to know what caused it now. Hope ya dont have too many issues when ya dig in further.
Good luck, and price a hydrailic roller, it hurts....
Re: wiped a lobe... expensive lesson [Re: Moparnut426] #1188070
03/02/12 07:13 AM
03/02/12 07:13 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Well now you got me wondering about using those 10 year old (new in box) Comp lifters and springs with a Hughes Whiplash cam...
Why cant this stuff just be simple...???
Re: wiped a lobe... expensive lesson [Re: Pale_Roader] #1188071
03/02/12 12:40 PM
03/02/12 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
10yrs old would put the lifters before the bad ones got dumped into the system , but you want to check and make sure they spin well first .
Re: wiped a lobe... expensive lesson [Re: JohnRR] #1188072
03/02/12 02:56 PM
03/02/12 02:56 PM
Space Station #5
Space Station #5
Cam was purchased about a year ago.
Lifters were definitely spinning before the accelerated wear started. I went to extra effort cleaning out the bores and test fitting the lifters at assembly. Judging from the wear pattern, it even appears it continued to spin after the wear started. It would have wiped a lot sooner otherwise. I'm pretty sure botched preload was the culprit.
Picking the next set of lifters right off the proverbial tree. Ordering direct from Topline Hylift.
-Jim
Re: wiped a lobe... expensive lesson [Re: 471Magnum] #1188073
03/02/12 02:59 PM
03/02/12 02:59 PM
Space Station #5
Space Station #5
I should mention that the set of Comp Cam lifters I just received have no country of origin listed on the packaging. They're going back un-opened.
-Jim
Re: wiped a lobe... expensive lesson [Re: 471Magnum] #1188074
03/02/12 03:17 PM
03/02/12 03:17 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I would measure the lifter bores
Re: wiped a lobe... expensive lesson [Re: scatpacktom] #1188075
03/02/12 03:28 PM
03/02/12 03:28 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
don't be alarmed when you fire up the XE275HL cam...it's a noisy one too.
I was worried at first when I heard mine, sounded like a sewing machine! but, 4,000 street miles and it never skipped a beat.
**Photobucket sucks**
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188076
03/07/12 06:09 PM
03/07/12 06:09 PM
Space Station #5
Space Station #5
Took the day off today to pull the motor and tear it down.
Pretty much have finished the tear down. All that is left is pulling the crank.
Removed the pistons and rods to find those journals lightly scoured. I think it will clean up with a polish though.
Bigger concern is the piston skirts and bores. Some light scuffing there. Not sure how much would be considered acceptable. I'll try to post a photo later. Hopefully they are salvageable.
Plan is to get the block and crank to the machine shop tomorrow.
-Jim
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188077
03/07/12 06:18 PM
03/07/12 06:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Did you tear it apart like I did the last time I had to do that?
__
Re: wiped a lobe... expensive lesson...update [Re: Challenger 1] #1188078
03/07/12 06:28 PM
03/07/12 06:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
__
Hopefully you swept before laying the pistons out ...
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188079
03/07/12 08:48 PM
03/07/12 08:48 PM
Space Station #5
Space Station #5
Here is a picture of the #7 bore. Seems to be the worst of them.
-Jim
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188080
03/07/12 09:14 PM
03/07/12 09:14 PM
AndyF Offline
AndyF  Offline
Chewing up a cam lobe is a real bummer. I lost my original 426W engine years ago that way. The lobe material went into the oil pump and then that sheared the pump drive and once oil pressure went away the rod bearings spun. You caught your issue sooner than I did!
I wrote an article on the subject last year. It is in the tech archives on this board if you want to check it out. I talked to a bunch of people in the industry and tried to find all the newest parts on the market to help flat tappet cams live. I think it can be done if you use the right oil, lifters, springs, coatings, etc.
http://www.moparmax.com/tech/2011/vi_8-flat-1.html
Re: wiped a lobe... expensive lesson...update [Re: JohnRR] #1188081
03/07/12 09:29 PM
03/07/12 09:29 PM
Space Station #5
Space Station #5
The carbon build-up acts as a protective coating.
-Jim
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188082
03/07/12 11:34 PM
03/07/12 11:34 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
sorry to hear that. My 360 wiped a cam a few years back. It ran fine for several years, and I would always use Mobile-1 in it. The cam lifter failure was right about the time all the companies changed to the "new" lower ZDDP additives (maybe 10 years ago?) The metal from the wiped cam and lifter made a mess of the oil pump, bearings and some cylinder wall scratches. I was able to have the machine shop re-hone the cylinders, and I rebuilt it with new bearings, rings, and a slightly hotter cam. I quit using Mobile-1 and only use the "Race" oil in the engine.
Re: wiped a lobe... expensive lesson...update [Re: 471Magnum] #1188083
03/08/12 09:22 AM
03/08/12 09:22 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Complicated subject!
Basically, over the last 10-15 years, there has been a "perfect storm" of conditions contributing to this widespread problem. The three main ones:
> Detroit totally stopped using flat tappet camshaft, resulting in a loss of dependable, low-cost tappet and cam-blank suppliers
> The guys who knew how to make the above "for generations" are dying off
> ZDDP levels in oils have slowly been reduced. No law against ZDDP, but it isn't good for cats, and the EPA forces automakers to give long "low emissions" warranties
The fixes? Also multi-prong:
> Use oil with enough ZDDP (EG: Mobil 1 15W50, etc.) or an additive
> Use lifters with either a ceramic-composite face, or the 0.012" laser-drilled hole in the face
> Avoid long periods of idling
> Don't go crazy with valve spring pressure. If "enough is enough", "too much" ISN'T better!
> And, most important: Assure that your new engine fires INSTANTLY (timing right, float bowls filled, shot of ether, etc.) and doesn't see under 2,500 RPM for the first 20 minutes or so.
Rick
Page 2 of 4 1 2 3 4
