Well, thanks to you all I got the engine out today. It was more work than I anticipated, but I guess that's where Murphy came into play. I hate to admit this, but I wasn't aware that I needed to remove the starter. I had removed everything according to the manual, which did not mention removal of the starter. The engine kept getting hung up on something, and sure enough, there it was. My problem now is that I apparently need to remove the flywheel before I can attach the engine to the stand. I can't get those bolts loose. I managed to get one of the 6 bolts loose.
I guess I need to hit them with the impact wrench. That won't break them, will it? Also, how do I know if the flywheel needs resurfaced?
Thanks again for all your help!
![](/ubbthreads/images/graemlins/thumbs.gif)
