Power steering pump brkts? #118630
09/10/08 12:04 PM
09/10/08 12:04 PM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
Hi, I have a 69 Dart with a 340ci and i was wondering if anyone out there had pictures of how the 4 power steering pump brakets are installed? Also has anyone ever had to remove the broken off piece of oil dipstick tube that is in the block? And how did you do it? It was missed during the rebuild. Thanks Bob
Re: Power steering pump brkts? [Re: preston] #118631
09/10/08 01:09 PM
09/10/08 01:09 PM
Re: Power steering pump brkts? #118632
09/10/08 01:18 PM
09/10/08 01:18 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
sure do!
www.hoffmanswinnerscircle.com/
The one they don't have shown is the 64-69 Small block (iron water pump housing) with Saginaw pump.
Re: Power steering pump brkts? [Re: autoxcuda] #118633
09/10/08 03:28 PM
09/10/08 03:28 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
this one 69 later small block
Re: Power steering pump brkts? [Re: satgtx] #118634
09/10/08 04:04 PM
09/10/08 04:04 PM
So Cal
So Cal
That's for a 1970 and up with the aluminum water pump housing.
Here's a bad picture of the 69 and down saginaw pump setup for the cast iron water pump. It only has two brackets.
Re: Power steering pump brkts? [Re: autoxcuda] #118635
09/10/08 09:23 PM
09/10/08 09:23 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
i posted the wrong one
