1969 Barracuda /6 to 440
#1183509
02/21/12 03:57 PM
02/21/12 03:57 PM
Posts: 165 Edmond, Oklahoma. U.S.A.
Madcoy
What oil pan is needed? My 727 is from a truck what issues am I going to have. Will be upgrading the Tbars and rebuilding the front end and doing a disc brake convo, radiator and trans cooler. Headers? What is best? Ideas? Let me hear from YOU!!
My American PitBull is smarter than your Poodle
Re: 1969 Barracuda /6 to 440
[Re: Madcoy]
#1183510
02/21/12 04:13 PM
02/21/12 04:13 PM
Posts: 1,030 ohio
67mprfan
ohio
Are you using motor mounts or front engine plate,schumacher has a set-up with using mounts,also if you don't mind making wide turns fenderwell headers is a budget way to go or find some pro-parts if you don't mind cutting fenderwells,tti makes undercar header but is pricey from what i hear,oil pans the 187 pan should work but double check or aftermarket 1 to(depends on your plan use for the car)might be hood clearance issuses also depends on intake and air cleaner...p.s check clearance for p.s pump if using 1 might have to go manual
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#1183511
02/21/12 04:25 PM
02/21/12 04:25 PM
Madcoy
At this point I dont think I want to cut the fenders. This is a very nice car. But still factory /6. I will check with tti. This will be a street car.
[Re: Madcoy]
#1183512
02/21/12 07:14 PM
02/21/12 07:14 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Lots of things to consider. The "187" pan from a C-body (699, also as I recall) is the best fit, but the idler may still hit. Using a 73-up centerlink gives more clearance due to the idler and pitman arm studs pointing down. Spend some time in the tech pages at www.bigblockdart.com to answer some of your questions and probably raise more.
[Re: Jim_Lusk]
#1183513
02/21/12 08:20 PM
02/21/12 08:20 PM
RapidRobert
need the pan w the idler indentation. The shallow /6 centerlink will clear fine.
[Re: RapidRobert]
#1183514
02/21/12 11:03 PM
02/21/12 11:03 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Better at least put subframe connectors in it too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: RapidRobert]
#1183515
02/23/12 03:21 AM
02/23/12 03:21 AM
Jim_Lusk
Fresno, CA
No such thing as a 67-up slant centerlink. They are all the same for 67-72. Then the design changed for 73 and was used until the end in 1976. The later one should clear better and possibly clear even the un-notched pan. I will be finding out later this year.
[Re: Jim_Lusk]
#1183517
02/23/12 03:15 PM
02/23/12 03:15 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Can't switch to that centerlink without also changing the steering box to a 73 and later box ... fyi
