Re: "Elvis" in the 7's
[Re: 9 Sec Phill]
#118230
09/12/08 03:16 PM
09/12/08 03:16 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I don't know about anyone else but I wouldn't have fiddled with it untill I made a pass or two with the tune Monte gave him at the beginning of the week.
Makes no sense to change it from where it was till you see what it does at the new track.
Probably killing him to have all this NOS sitting ther unused, I can see him going crazy wanting to throw more at it.................
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: 9 Sec Phill]
#118231
09/12/08 06:28 PM
09/12/08 06:28 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
When he left it looked like he spun a little and at around the 60' mark it back fired. He will figure it out im sure..best of luck to him and crew...Phill
60' may be when the 2nd stage comes in and a solinoid was stuck.
Post deleted by Defbob
[Re: blownzoom440]
#118232
09/12/08 06:30 PM
09/12/08 06:30 PM
#118238
09/12/08 08:23 PM
09/12/08 08:23 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Has Eddie been able to replace the broken valvetrain parts?
Where is sixpackgut with an update?
Beats Me?
Doesn't look like fun though..
Notice the lifters by the radiator??
Maybe this is why Ray hasn't been posting..
Chris...
[Re: Chris'sBarracuda]
#118239
09/12/08 09:15 PM
09/12/08 09:15 PM
Posts: 6,295 U.S.
moparniac
U.S.
It seems to me on eddies 440-1 motor he made about 800hp and sprayed 700hp,,,,,,, now hes making almost 1200hp an spraying less in to pick up a couple tenths??? i dont get it??? wiht properly setup chassis and more spray i think he could beat any of the cars...
Mopar Performance
[Re: moparniac]
#118241
09/12/08 11:57 PM
09/12/08 11:57 PM
Sledge_57
Dearborn Hts, MI
Well he said he was spraying 700, how much hp did all that spray really add is the question, a far cry from 700hp I'll bet.
A properly setup chassis is the key here, that Nova's a full chassis car I believe, it's gotta work better than Eddies "street car"
Doug
[Re: moparniac]
#118242
09/13/08 12:16 AM
09/13/08 12:16 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
yeah, it has way less nitrous on it and yeah it will go much faster....but...the first pass at BG was the first time this motor had EVER been down the track on 2 kits. Some may go out and go balls to the wall right off the bat and spray the snot out of it with both kits, but that is not my style. It is Eddie's car and he can do as he pleases, but if the plan calls for just "pilling it up and hoping for the best" with no testing, I'm out. Want no part of anything like that. Eddie is leading his class by a bunch, Larson has more if needed, trust me. Larry is playing to win, if Eddie throws down a number, you can bet Larry will respond. The 7.75 he went at BG was with only 15lbs of boost.
Monte
[Re: Monte_Smith]
#118245
09/13/08 12:43 AM
09/13/08 12:43 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello Monte,
Is Eddie keeping it down due to the hurt valve train? What do you make of the explosion near the 60' mark that appears to be nitrous related? Any other insight?
thanks
Damon
[Re: mopardamo]
#118246
09/13/08 02:12 AM
09/13/08 02:12 AM
Monte_Smith
North Alabama
Hello Monte,
thanks
Damon
I have no idea, have not talked to Eddie, nor do I have an idea what he is doing with the tune, or what issues he is having with the motor. I do know that Larry plans to make a moderate pass to seal the win and then turn the wick up. I would not be surprised at all to see a 6 sec blast.
Monte
[Re: Monte_Smith]
#118249
09/13/08 02:23 PM
09/13/08 02:23 PM
Sledge_57
Dearborn Hts, MI
Hello Monte,
thanks
Damon
Monte
I hope he does it, I'd love to see that Nova run a 6
Doug
