Springs for the Mopar 528 solid cam? #1181802
02/18/12 11:00 PM
02/18/12 11:00 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I'm looking to build up a small block and get a 528 solid cam. Anybody know of a good valve spring for it? The Mopar springs are expensive
Re: Springs for the Mopar 528 solid cam? [Re: DusterKrazy] #1181803
02/18/12 11:53 PM
02/18/12 11:53 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
Hughes 1110 is the first spring I would look at.
Re: Springs for the Mopar 528 solid cam? [Re: 1970sixpak] #1181804
02/19/12 01:55 AM
02/19/12 01:55 AM
montreal, quebec,canada
7e5dartsport Offline
comp cams 995-16 are what is recommended as springs for there line of solid-cams . available from summit for around 100$ a set of 16. they migth require the use of teflon seals- and therefore machining the heads- as they are true double valve springs. i think that with the mopar 528 cam you need to have the heads machined anyway - need to cut the valve guides for retainer to guide clearance- so the 995 seams to be the cheaper alternative, even compared to a single valve spring.
fully legal sounds the same as full illegal...
