Re: My new Torque plate from Performance only!
[Re: Dodgem]
#1180119
02/20/12 02:47 PM
02/20/12 02:47 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Just as a note way back in time (1992) my machinist (new to me then) talked me into going from .040 over to .060 over so we could smooth out my bores from not having a torque plate. He had one so I went in after the motor was bored and he showed me how nice and round the cylinders were. then he bolted on the torque plate and he showed me how much that pushed the cylinders out of round! Then showed me how they now honed out straight. he too wants the head gasket you will be using nice I went bigger bore head gasket two years ago so they are the ones 1105 I'll be using so I have used ones to use! So the only change I made was the + 4 cubic inches and we went up .5 in compression 10 to 1s to 10.5 (or standard 10 to 1's to 10.5 six barrel pistons) same cam heads and all and it ran at least .55 better all the time so I was sold! So if you give .15 to .2 to the little raise in compression and cubes the .4 to .35 was from better sealing bores!!! Since Dan's looked so pretty and I could not talk him into boring his plate out from 4.380 to the 4.5+ I need now I bit the bullet for a real nice piece!!
