Bizarre Fel Pro Rear Main Seal #1178528
02/14/12 07:16 PM
02/14/12 07:16 PM
Out in Left Field, NY
bobs66440 Offline OP
I found this in my gasket kit. It says to fill the side seal cavity with RTV, then dip the pipe cleaners in WATER and push them into the cavity?? Has anyone used these before? Seems really odd to me.
Re: Bizarre Fel Pro Rear Main Seal [Re: bobs66440] #1178529
02/14/12 07:20 PM
02/14/12 07:20 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
They eliminated the rubber vertical seals and replaced them with RTV. RTV requires water (usually from the air) to cure. The wet pipe cleaners introduce the needed moisture.
I've used a couple of them. They seem to work just fine.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Bizarre Fel Pro Rear Main Seal [Re: bobs66440] #1178530
02/14/12 07:24 PM
02/14/12 07:24 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Yes, on the 400 I rebuilt a few years ago I used that kit. It seemed really odd to me too, but I followed the instructions and it doesn't leak.
It does looks pretty crappy though and the RTV really gobs outward toward the main cap. Make sure you push the pipe cleaners all the way down too. When I squeezed in all the RTV I could down the side channels, I could still see light coming though near the bottom when I checked with a flashlight. After pushing the pipe cleaners down it seemed to seal. I also RTV'd the retainer to the block from the back as well.
Like I said it works, but is pretty messy.
Re: Bizarre Fel Pro Rear Main Seal [Re: 440newport] #1178531
02/15/12 02:40 PM
02/15/12 02:40 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The silicone and pipe cleaner is hit and miss at best IMHO. Dipping the pipe cleaner in water and inserting it into the cavity is to aid in the curing of the silicone RTV by releasing oxygen within the cavity.
I designed these and have been selling them since about 1991 with excellent success. Just made some dimensional changes in my tooling to make the installation easier for those that don't use them every day or have the motor on the stand.
Re: Bizarre Fel Pro Rear Main Seal [Re: roadhazard] #1178532
02/15/12 02:42 PM
02/15/12 02:42 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
A profile view.
The hollow core is for ease of compression
Re: Bizarre Fel Pro Rear Main Seal [Re: roadhazard] #1178533
02/15/12 02:50 PM
02/15/12 02:50 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
That whole Felpro Kit Sux. I took the best of care doing my 440 and it leaks a few drops and is all over the trans pan all the time. Mine is probably the seal not the sides though. This topic comes up all the time. Use the rope seal, call Carquest.
Re: Bizarre Fel Pro Rear Main Seal [Re: roadhazard] #1178534
02/15/12 02:54 PM
02/15/12 02:54 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Here's a pic of them installed. This is the previous design (different color for identification) Both are very effective. One is just a little easier to install than the other and come with complete instructions
Re: Bizarre Fel Pro Rear Main Seal [Re: roadhazard] #1178535
02/15/12 09:09 PM
02/15/12 09:09 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Wish I knew about these when I rebuilt my 440 a few years ago....had a rear main seal leak immediately after break in.
Decided to change out the stock retainer for the billet aluminum one Mancini Racing sold with the o-ring side seals with engine in the car....STILL leaks
1MYTGTX
Re: Bizarre Fel Pro Rear Main Seal [Re: 1MYTGTX] #1178536
02/16/12 08:50 PM
02/16/12 08:50 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I bought the same billet seal housing from Mancini. Mine leaked as well. When I took it apart, the problem was clear. When you slide the housing with the side seals into the block, the little rubber seals stretch. Over time, the seals pull back. I had a least 1/4 gap at the bottom of each seal. I had cut them off flush when I installed them. I got new seals (didn't want to spend more money on another housing). This time I added RTV into the grove before I installed the seals. Hopefully this will keep them from pulling back. I also waited a few hours before I trimmed the seals flush, maybe gave the seals some time pull back. From the back of the block I also RTV'ed the seam between the block and the seal housing. I haven't fired it up yet to see if this worked.
Nothing worse than having a re-done car and engine that leaves oil everywhere you park.
Re: Bizarre Fel Pro Rear Main Seal [Re: bri440] #1178537
02/18/12 01:22 AM
02/18/12 01:22 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
what is what say ppl about Dodge ?
Drips
Oil
Drops
Grease
Everywhere ?LOL
I went with rope and felts? ( or whichever material is ) seals, stock pieces from an Old NOS kit and working great by now.
Of course I helped a little bit FILLING WITH RTV the outside face of seal retainer with block ( the Groove left there )
LOL
Re: Bizarre Fel Pro Rear Main Seal [Re: roadhazard] #1178538
02/18/12 10:44 AM
02/18/12 10:44 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Very nice design. I hope you get your website up soon.
Garth
Re: Bizarre Fel Pro Rear Main Seal [Re: Big Wedge] #1178539
02/18/12 10:47 AM
02/18/12 10:47 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
sure glad i stashed some of the oldies.
Re: Bizarre Fel Pro Rear Main Seal [Re: lewtot184] #1178540
02/19/12 01:02 PM
02/19/12 01:02 PM
Idaho
K
kdtjb Offline
kdtjb  Offline
K
Idaho
X2
Re: Bizarre Fel Pro Rear Main Seal [Re: bri440] #1178541
02/22/12 08:51 PM
02/22/12 08:51 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I know what you mean...
