Regrouping on 360 , input from group?
#1177564
02/13/12 03:14 AM
02/13/12 03:14 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
So...Got over crying in my sake, and got back on the job. Got what was supposed to be a low mile 78 creampuff 360 truck motor, from a friend, for 200.If it wasn't so bad it would be funny.Some cro magnon resized the conn rods so they are just about ALL .002 out of round SIDEWAYS! The crank is cut .020 on the rods only. (not one but TWO resizing stamps on the crank, one says "R .010 11/87" then ANOTHER says "R.020 1/88", somebody had issues with their rebuild...) But all is not lost.Block shows very little bore wear, like .001, no ridge. Crank is .020 on the rods, and is spec. I am thinking S.I.R. rods because it's the least expensive way to go, and try to recycle the stock dish tops with new rings, if they crash in the pin pressing stage, I will go with new std bore pistons like speed pro hypers.Mild cam,small valve heads,melling pump, windage tray, stock pan, LD340, eddy 750, , factory style hi stall convertor. Hopefully will result in a durable SB that will get us by for a few years until the Oregon move. I considered recycling the "ported" heads from the ill fated predecessor, but the porting job is sort of suspect,intake ports are baby-butt smooth, and IIRC they are supposed to be left ROUGH to help keep the fuel droplets in suspension. On of my consulting machinists is pretty experienced, and reminded me I may kill all the bottom end torque by going that route, too. Group thoughts? Vehicle is 73 challenger w/ TCI 727 (used) currently 3.91s with 28" tall tires, but in deference to the highways you guys have, will eventually get 2.76s with SG. Thanks, C ![](/ubbthreads/images/graemlins/bow.gif)
Re: Regrouping on 360 , input from group?
[Re: Sixgun]
#1177565
02/13/12 11:52 AM
02/13/12 11:52 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
either get used stock rods out of a 318, or some SCAT I-beams.
since you're going through the trouble, KB107's are only like $200...
[Re: mod5v]
#1177569
02/13/12 01:39 PM
02/13/12 01:39 PM
Sixgun
Western Washington
Patrick,I am thinking the same thing, BUT all I really want is to avoid boring it,and if I can scoop some better compression for cheap that's a bonus. So maybe a std set of KBs...there IS a super deal on sealed power Hypereutectics on Flea Bag with rings ,like 139,free freight but not to hawaii. but if Johns are decent and usable, a 73 set probably would be flat tops.Machinist says rods are fairly stable, that is they tend to stay "round" if not traumatized ? John: Thank you, I will not say "no", am keeping all options open. Robert: HI! Yes I am a bigger fool than I thought possible, move tentatively set for about 2 years when Wifie gets out of school.And I get to meet my "customer service" representative in PERSON!!! Mod 5V: I thought the 360 had enough cubes to do the job as long as I keep the cam specs reasonable, and still make some torque. My only other head choices are the 78 smoggers that came with the truck motor,or refurbish some small valve 340's which would probably not be cost effective. Nice to be back and have all the good input, that's why I come here. ![](/ubbthreads/images/graemlins/beer.gif)
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: JohnRR]
#1177571
02/14/12 12:30 PM
02/14/12 12:30 PM
Sixgun
Western Washington
Just about ready to pull the trigger on the CP Hypers, rings, and eagle SIRs. Still researching.(and trying to keep cost down without sacrificing durability) ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Paul_Fancsali]
#1177574
02/14/12 04:25 PM
02/14/12 04:25 PM
Posts: 12,015 Finally a HUSKER again
Moparnut426
FYI, Eagle SIR rods need a LOT of work to make them true and runnable, stick with the Scats, I have used them bunch in a few different builds, and never had to touch much at all, a little small end sizeing, but thats it.
The SIR rods took a LOT, and I mean a lot, every rod was very tight on the specs, and every pin bushing was so tight with light oil the pin wouldnt slide in without some good coaxing.
Kasey
[Re: Moparnut426]
#1177575
02/16/12 01:11 AM
02/16/12 01:11 AM
Sixgun
Western Washington
OK moparnut426,I am going insane with this, but I must pause and THANK YOU!I was none too happy to see what your experiences were with SIRs... BUT I followed up BEFORE I bought, and guess what? You ain't the only one who has had issues with those (I know you knew that, I am just being cheeky) SO, I see a very good price on SCAT I beams from CNC Motorsports, like 290 landed . CNC only sells KB hypers,STD bore, and they would run about 360 delivered... I really liked the Speed Pro H116CP which I can get from someone else for about 340 with hastings rings, pins and locks, delivered. Which piston has a better rep?I hear the KBs like to lose the top ring land, but only when pushed HARD... Looks like the scat rods are a no-brainer, but I would like more input on the pistons. Please? Case ![](/ubbthreads/images/graemlins/confused.gif)
[Re: Sixgun]
#1177579
02/16/12 11:10 AM
02/16/12 11:10 AM
RapidRobert
SO, I see a very good price on SCAT I beams from CNC Motorsports, like 290 landed . CNC only sells KB hypers,STD bore, and they would run about 360 delivered... I really liked the Speed Pro H116CP which I can get from someone else for about 340 with hastings rings, pins and locks, delivered. Which piston has a better rep? but I would like more input on the pistons.
hey Bear, I've dealt w CNC before several times & they're good people. I think the speed pros will have less deck height than KB's & dont you want to go 30 over & start fresh? Are you wanting quench?
[Re: JohnRR]
#1177580
02/16/12 11:22 AM
02/16/12 11:22 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Casey I think the 73 pistons have a dish , I'll know later.
Casey the pistons have a dish , they actually look like replacements because they are stamped std on the tops ? don't look bad , it did start to eat one cam lobe after being rebuilt only has hours of run time .
[Re: DaytonaTurbo]
#1177581
02/16/12 11:25 AM
02/16/12 11:25 AM
JohnRR
John's 73 pistons would probably be a set of low-cr smogger pistons.
They probably are , I can't remember how far in the hole they were though, I'd have to measure a CH on them.
When I say cheap I mean $25 plus the shipping.
