Anyone know K-cars? 2.2 Q's. #117535
09/08/08 09:40 PM
09/08/08 09:40 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Hey all. Im working on a little 89 Reliant K. It has a TBI 2.2.
It idles all over the place sometimes and is real weak off the line. (i know its only a 2.2.. but my 88 aries was much stronger off the line). I went to check the timing and with the coolent temp sens plugged in it jumps all over the place. With it unplugged it jumps up and down a deg or 2.
Also, the timing belt has a mark on it from the grove in the tensioner pulley. There are no cracks and it doesnt look like it jumped timing. What is the life expectancy on these belts?
Thanks.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117536
09/08/08 10:05 PM
09/08/08 10:05 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Well, It's been a while since I had my LeBaron GTS Turbo 2.2 L, but I'll try.
You are doing the right thing by disconnecting the coolant sensor whilst checking the timing.
The "Hall Effect Sensors" in the distributors fail quite often , and they are cheap and easy to replace. First, check that connector, though !
The timing belts are rubber (of course) and the maintenance interval is around 60K miles. My car was still running fine at 173K with one timing belt change. I had gone through 3 head gaskets by then, though ( it WAS a Turbo).
Good luck.
Re: Anyone know K-cars? 2.2 Q's. [Re: IronWolf] #117537
09/08/08 10:16 PM
09/08/08 10:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep, I always do the t-belts at 60k, however these are non-interference engines, so no huge loss if it snaps on you.
I would remove, clean and then reinstall the AIS motor on the throttle body. Sometimes that helps, other times does nothing. Have you tried checking for codes just in case by chance the computer knows something is wrong?
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117538
09/08/08 10:18 PM
09/08/08 10:18 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
These cars will run REAL bad if they starve for fuel. If the fuel filter is old, put a new one on.
I personally was in an 88 dakota when the belt threw on its 2.2...we dragged it back to the house and threw a new belt on...good to go. I wouldn't be too worried.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Anyone know K-cars? 2.2 Q's. [Re: goldduster318] #117539
09/08/08 10:33 PM
09/08/08 10:33 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
OK ill pull and clean the idle motor. I'll also change the fuel filter.
I still dont know if the jumping timming is making the idle erratic or if the erratic idle is making the timing jump around.
Here's the timing belt. Ive been looking at the FSM and it doesnt look like a big deal to change. I'll just do it so i dont get stuck 500 miles from home.
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117540
09/08/08 11:07 PM
09/08/08 11:07 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Hows the compression? Did you do a recent compression test? 2.2 engines tend to carbon up the intake valves to the point of plugging up the bowl. It usually happenned in the center two cylinders. That could explain the down on power feeling. Usually the head gasket goes next. Combustion chamber treatments every 10,000 miles or so is recommended to keep this from happenning. I have removed a few heads and physically removed the carbon buildup, polished up the valves/bowls etc. That tends to restore the power.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Anyone know K-cars? 2.2 Q's. [Re: racealittle] #117541
09/08/08 11:28 PM
09/08/08 11:28 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Would a differance in compression from cyl to cyl be a sign on a gummed up intake valve?
I took apart a TBI 360 once and the intakes where so gunked up i dont know how it ran...
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117542
09/08/08 11:59 PM
09/08/08 11:59 PM
racealittle Offline
racealittle  Offline
If the air can't get into the cylinder to get compressed...? I would think that if a cylinder or two are not funtioning properly on a 4 cylinder (loss of efficiency), that might explain why it is down on power. That was my experience. I didn't ask for it to be my experience. The service manual mentions frequency of combustion chamber treatments to be important. We just have extremely poor quality gas in Canada. There must be some sort of reversion problem with the center cylinders that the engineers knew about and chose not to fix until they got away from throttle body injection.
Re: Anyone know K-cars? 2.2 Q's. [Re: racealittle] #117543
09/10/08 04:29 PM
09/10/08 04:29 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Well the compression checks out. It seems to be running rich at times. I changed the O2 sensor with no change. If i rev it in N it spits some black smoke. And the cat seems to get real hot real quick
I noticed the hose to the EGR is plugged. Could this effect idle if its closed all the time?
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117544
09/10/08 07:08 PM
09/10/08 07:08 PM
Manitoba, Canada
Manitoba, Canada
No, if the EGR is stuck closed, you are fine. Sounds to me like it's time to put a fuel pressure gauge to it so see if that's a problem.
Re: Anyone know K-cars? 2.2 Q's. [Re: DaytonaTurbo] #117545
09/10/08 07:46 PM
09/10/08 07:46 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
K. Good advice. Ill have to rent a gauge for EFI.
Tonight im working on replacing the timing belt.
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117546
09/10/08 09:31 PM
09/10/08 09:31 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Well since i dont have the special mopar tool PN 45534354.34455,3 to adjust the belt tension im am just guessing here...
http://www.youtube.com/watch?v=xh4KDJFBxUM
http://www.youtube.com/watch?v=l5OsoMgRJFM
It flaps up and down i'ed say 1/2" maybe. It sounds like i dont want this thing to be tight like a Vbelt but i hope its not to loose
And for some reason with the engine half apart it started to idle normal.
Re: Anyone know K-cars? 2.2 Q's. [Re: CrAlt] #117547
09/10/08 10:10 PM
09/10/08 10:10 PM
Manitoba, Canada
Manitoba, Canada
Rule of thumb for the timing belt is you should be able to twist the belt to about 90* in either direction, but no further. If memory serves anyway.
Fuel pressure for an 89 should still be 14.5psi I think.
