426 hemi/keisler 5 speed...best gears? #1175139
02/09/12 01:35 AM
02/09/12 01:35 AM
kansas city, mo
rave_12000 Offline OP
kansas city, mo
getting ready to restore my 71 cuda vert. i have 426 hemi w/ keisler 5 spd. i have an 8 3/4 with the following pumpkins already built: 4.56, 3.91, 3.55, 3.23. i also have a dana 60 w/ 3.54. what to do???? what is best choice based on anyone's experience?
thanks in advance!
mike
Re: 426 hemi/keisler 5 speed...best gears? [Re: rave_12000] #1175140
02/09/12 02:23 AM
02/09/12 02:23 AM
PNW
Danan Offline
Danan  Offline
PNW
Most important question is: What do you want to do with the car?
Second most important question: What diameter tire are you going to run?
Suggestion: If you are looking at sticky tires and/or hard launches, I'd ditch the 8 3/4" all together.
Re: 426 hemi/keisler 5 speed...best gears? [Re: Danan] #1175141
02/09/12 04:30 AM
02/09/12 04:30 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am going to run a 60 with 3.55 gears. This is a 572 hemi and a A833 with the 3.09 first gear with 27" tires. Oh do the upgrade and install the dana 70 ring and pinion with a powerlock in the 60 housing. Tim
Re: 426 hemi/keisler 5 speed...best gears? [Re: astjp2] #1175142
02/09/12 04:40 AM
02/09/12 04:40 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Tire diameter? Do you have the .64 5th gear ratio or the .82?
Re: 426 hemi/keisler 5 speed...best gears? [Re: DaytonaTurbo] #1175143
02/09/12 12:24 PM
02/09/12 12:24 PM
kansas city, mo
kansas city, mo
i am going to run a 275/60/15 tire. i will have to check on the 5th gear ratio. i wont be drag racing the car by any means. i think that i should probably put the dana 60 in there...because it would only be appropriate for "badness". just wondering if i should change the gear ratio in the dana. how hard is that and what all dana 60 gears will interchange. most of my experience is with 8 3/4.
Re: 426 hemi/keisler 5 speed...best gears? [Re: rave_12000] #1175144
02/09/12 12:29 PM
02/09/12 12:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yea, helps to know what OD is in your TKO. if you had the .64OD, I'd say go 4.56 on your gear ratio! but 3.91s on car tires would probably be fine with the .64OD.
if you have the .82OD, then I'd say keep your 3.55s.
I had a big block Dakota with the TKO600, .64OD, and 4.56 gears on 28" tires.
I could cruise the highway at 70mph and only turn 2400 rpm.
for a hemi 5-spd combo, I would highly suggest using the Dana, but on street tires the 8.75 should last as long as it never hooks up.
**Photobucket sucks**
Re: 426 hemi/keisler 5 speed...best gears? [Re: DaytonaTurbo] #1175145
02/09/12 12:46 PM
02/09/12 12:46 PM
MA
1968 Charger B5 Offline
MA
If using the .64 unit.....
run 4:10s...with 27.5" tire you will do roughly 80 around 2700-300 rpm....and more gear will be too much...and less is up to you....
use the overall chart to figure out what you want your cruising speed/rpm range..
1968 Dodge Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
Re: 426 hemi/keisler 5 speed...best gears? [Re: rave_12000] #1175146
02/09/12 03:13 PM
02/09/12 03:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Put the dana in it and leave that ratio in it, no matter waht size tires You can always run it in 4th or 3rd gear for hill climbing or curves insted of running the motor at a higher RPM in 5th all the time BTW, ALL OEM Hemi 4 speed cars only came with the Dana 60
