original tire size/dia '68 GTX #1174975
02/08/12 09:15 PM
02/08/12 09:15 PM
RapidRobert Offline OP
My 1st Mopar. pretty sure 14's & Magnum?? wheels. Thank you for your time.
Re: original tire size/dia '68 GTX [Re: RapidRobert] #1174976
02/08/12 10:14 PM
02/08/12 10:14 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I'm pretty sure they were F70/14 with a 26.4" diameter.
Re: original tire size/dia '68 GTX [Re: RapidRobert] #1174977
02/08/12 10:27 PM
02/08/12 10:27 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
...unless it is a hemi of course!
Here is a link to the 68 data book tire page.
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1968/68_Belvedere0026.jpg
Re: original tire size/dia '68 GTX [Re: moparfan53] #1174978
02/08/12 10:36 PM
02/08/12 10:36 PM
no Hemi but it was a convertible . Thanks guys for the info. What's going on is I have a 3.91 going into an A body & I remem how buzzed the GTX 440 was w the 4.10's & wanting to get a rough handle on how much larger dia tires I need now to slow down the A body project rpm some which is going to be a subjective decision EDIT Canuk it was your other thread that got me thinking about this & I wanted to confirm the size (was over 35 yrs ago). The big Rocky Manginelli swap meet in Lincoln is coming up in a month & prob can score some 15" ralleys and early A's can take a large dia tire at least in the rear wheelwell
Re: original tire size/dia '68 GTX [Re: RapidRobert] #1174979
02/08/12 10:40 PM
02/08/12 10:40 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Why not decide on the tire you want to run and then gear it for the rpm you want to cruise?
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: original tire size/dia '68 GTX [Re: phantomx] #1174980
02/08/12 10:45 PM
02/08/12 10:45 PM
because I have no wheels/tires on hand other than 14" ralleys in front & I have a good 742 3.91 sure grip which ain't going nowhere
Re: original tire size/dia '68 GTX [Re: RapidRobert] #1174981
02/08/12 11:17 PM
02/08/12 11:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
'68 440 gtx would have had an f70x14 redline. a hemi would have had f70x15.
Re: original tire size/dia '68 GTX [Re: lewtot184] #1174982
02/09/12 12:19 AM
02/09/12 12:19 AM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Bob,
A 3.91 gear with 28" diameter tires will give you the equivalent of a 3.44 gear. Pretty nice for all around driving. The larger the tire, the higher the gearing you will end up with.
Re: original tire size/dia '68 GTX [Re: moparcanuk] #1174983
02/09/12 11:34 AM
02/09/12 11:34 AM
Exactly. Thanks guys!
