Re: Adjustable Strut Rods
[Re: curleysracecars]
#1174917
02/10/12 04:40 PM
02/10/12 04:40 PM
Posts: 5,405 Pikes Peak Country
TC@HP2
Pikes Peak Country
How many people are interested in these strut rods?
Didn't even know you were offering them for sale until 12 replies in to the thread. Asking for reviews isn't the same as asking for a sale.
Price will be a consideration for some. New standard struts can be had for $110. Adjustables are around $300, but are being made by branded manufacturers with reputations and history behind them. Is your offering going to distiguish its self in the marketplace by being lighter, stronger, less expensive, or something else?
I would like to see someone make a tube upper arms that will top out and hit the frame before the balljoint goes into a bind and limit the suspension travel.
I'm not the most savvy drag race tuner, but I'd think you would be more interested in getting the rear suspension instant center to be more inline with the neuteral plane to reduce the wheelstand instead of putting more front suspension travel in to promote the wheelstand. But, I know some SS class racers purposly use the wheelstand to gain traction, so I'm not sure if that is the case with your set up.
[Re: cageman]
#1174918
02/10/12 05:46 PM
02/10/12 05:46 PM
Posts: 186 Middleton, ID
curleysracecars
Middleton, ID
I guess I was hoping people would ask how much and how long to get them...my mistake. I can do them for right around $175. Should have a definite price early next week. Thanks to everyone whose given input!
Kyle Curley
[Re: ThermoQuad]
#1174920
02/11/12 01:42 PM
02/11/12 01:42 PM
curleysracecars
Middleton, ID
Thanks for the input Tom. I would not call them "better" than what RMS is selling. I do believe they are stronger in tension and compression, but by no means are the RMS units going to fail. These are probably slightly lighter than RMS pieces as well, but not enough to worry about for most people. I am curious about this idea you mention of a "monte carlo" bar and firewall brace. Any pictures of what youre referring to? I have plans this coming week to make up a subframe connector with a little different twist on it than usual...we'll see if I can make it work. Send me some pictures of this bar youre referring to and maybe I can come up with something similar. Thanks
Kyle Curley
#1174921
02/12/12 11:22 AM
02/12/12 11:22 AM
Posts: 2,477 Answering the call of the wild
ThermoQuad
ok mustang picture, but the idea is the same triangle shaped
there is/was a person making these for mopars but there are alleged issues with delivery, money, reputation.
Criteria: bolts in with the fender bolts & hole[s]drilled on on the firewall fits six packs and 4 bbls removable for maintenance
[Re: ThermoQuad]
#1174922
02/12/12 11:33 AM
02/12/12 11:33 AM
Posts: 23,295 Here
jcc
Here
I suspect that contraption is an improvement, especially over nothing, that "ox bow" crosspiece is likely almost useless IMO, obviously not easy to solve, but if that was my solution, I would not bother.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: Danny]
#1174924
02/12/12 03:47 PM
02/12/12 03:47 PM
curleysracecars
Middleton, ID
I see what you mean now Tom...thanks for the pictures. I will look into these. Having trouble staying motivated when there are a bunch of guys who are "in" on something, then when they are actually produced, everyone crawls under the shell and all of the sudden isnt interested anymore. I realize its part of business, but it gets annoying. Patience I guess... Thanks again for the input.
Kyle Curley
#1174925
02/12/12 03:54 PM
02/12/12 03:54 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Try to make it so that big bow in the transfers bar isn't there, make it as straight as possible. I personaly like the idea of a 3 piece system. That way when you're working on just one side of the engine bay, you can get away with taking out just one bar and not have to mess with the whole assembly.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ThermoQuad]
#1174927
02/12/12 06:29 PM
02/12/12 06:29 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
One suggestion, probably not the choice for a sellable product but if your building a Monte Carlo brace for yourself some Ford guys are incorporating ID tube clamps to make R&R quick & easy.... These come from the 4x4 world to allow roll cages to be removable yet retain strength.... Available in many sizes....
[Re: 1_WILD_RT]
#1174928
02/12/12 07:02 PM
02/12/12 07:02 PM
curleysracecars
Middleton, ID
Just looked over the Valiant a little bit...looks like with A/C, the bar would need to be about 2" behind the fan shroud...not a bad thing I guess. This would allow the bar to be straight. Problem I see is where to attach it to the firewall. Passenger side has a fairly nice flat area, but the driver side with brake booster and wiper motor doesnt leave any great places to attach the tubes to. I like the idea of having the side bars removable, but it will drive the cost up as one would expect. Also, a solid welded piece would be stronger and have less give to it, than if heim joints or clevis' were used. I think the best "happy medium", would be to have flat tabs on the brackets that bolt to the car. Then in the end of the tubes, would be a weld-in clevis that would slide over the tabs on the fenders and firewall, with bolts to secure them. Only issue then is making sure the tabs are "clocked" correctly so that the clevis' will go over them. Let me know your thoughts about the firewall mounting...I'll see if I can get something going. I have an idea for some "super-duper" subframe connectors that I am going to try to work on this week. They will tie into the rear subframe like all, but then pass through T-bar crossmember, then bend up and tie into the front frame rails. Hopefully not interfering with any tire clearance issues. I cannot believe the amount of flex the front end of these cars have...its rediculous. Back to the strut rod thread...
Kyle Curley
[Re: TC@HP2]
#1174930
02/13/12 04:32 AM
02/13/12 04:32 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
the big variable in making them is that they will need to fit the particular body styles with any particular engine, induction, ignition, and other optional items. Additionally, finding a stout enough bracing point on the firewall to locate the triangle is a big deal too as a plate sitting on sheetmetal really isn't a huge benefit to rigidity, even if the bar is triangulated.
I have thought the same thing. Small block cars have the distributor near the firewall, making the bracing a big obstacle to have to work around. I run a 440/493 in the Charger, so its not an issue for me. I DO have an Edelbrock RPM intake though, and I have a whopping 1/4" of clearance from the air cleaner to the underside of the hood. The lateral brace would have to take that into account.
[Re: cageman]
#1174933
02/15/12 12:08 PM
02/15/12 12:08 PM
curleysracecars
Middleton, ID
I agree with cageman...Im not really a fan of the Johnny Joints...they are expensive for one, and absolutely HUGE...I doubt they would even fit into the hole in the K-member.
Kyle Curley
