Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth #1174527
02/08/12 02:57 AM
02/08/12 02:57 AM
Harrison, NY
Classic Car Guy Offline OP
Harrison, NY
Have a question guys......
In your opinion's what is the best(performance) Head for serious street performance and occasional track outing's while on pump gas and somewhat nice street manner's. Looking to make 600hp/600lbs Trq in a 68 Charger with a 4 speed and Dana.
Trying to decide my best bet for performance using a roller cam in a 505 stroker around 10.5 comp, just need to decide Heads. Cost is not a concern as I want the best bang for the buck. The heads I'm looking into Indy EZ or 440-1, RPM Perf, Stealth and Victor. The head I purchase will be CNC ported,etc.
Please guys what should I do......
Thanks, Joe
Some of the Ride's...... 58 Ply Fury "Christine" Admin of: [url=http://www.ChristineCarClub.com]www.ChristineCarClub.com[/url 65 Ply Satellite [Email]9.43@141[/Email] 64 50th anniv 880 Custom 2dht 383 All Pwr. I'd Rather Be Hated For The Person I Am, Than Loved For The Person I Am Not!!!
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174528
02/08/12 03:28 AM
02/08/12 03:28 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I would use Max Wedge sized port window, either Victor or 440-1. Don't know much about the differnt CNC ported versions, might be that CNC ported 440-1's are a little on the big side for a relatively low CR 505. But otherwise I have good experiences about 440-1's in about 500 su in pump gas use.
Plynouth VIP '67 TT IC EFI
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: jyrki] #1174529
02/08/12 03:41 AM
02/08/12 03:41 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
600 ponies? i'd go with SR heads. my 'cuda had 650ish with a 451 & SR heads. had good street manners too. don't even consider Stealths.
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: jyrki] #1174530
02/08/12 05:01 AM
02/08/12 05:01 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Didnät notice you were aiming at only 600 hp. Then the smaller heads should be fine.
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174531
02/08/12 06:40 AM
02/08/12 06:40 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
in a 68 Charger ........... 505 stroker around 10.5 comp............ Cost is not a concern ........ what should I do......
Thanks, Joe
That's a weighty kinda B-body. I'd go Max Wedge Indy EZ's if it were me. They have the long valve/bigger dogleg port to feed that stroker. Header fitment isn't as big an issue as "-1"'s, standard rocker offset, but you'll need an intake too.
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Dean_Kuzluzski] #1174532
02/08/12 09:45 AM
02/08/12 09:45 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Can't say for sure without Cam specs...
The goal should be to raise and extend your powerband as high as possible without sacrificing any midrange torque to get there.
If you already have headers that fit I'd look at a Max wedge EZ-1...though they're not my #1 favorite power maker head (due to the somewhat compromised {fitment vs flow} exhaust port), the excellent intake port makes most of that back up.
440-1's in CNC trim have the most power potential and with a 4 speed a somewhat "oversized' head may actually make the car more tractible at low/part throttle.....again with the right cam.
WIZE
In Car:
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174533
02/08/12 10:33 AM
02/08/12 10:33 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
is money a concern?
Edlebrock has been a good head all these years...if 600 hp is all you want to make, do the RPM's fully ported and opened to max wedge port...have them flowed and match a cam to it...use their Victor intake and..600+ ponies depending on compression and parts fitment..
a little sidebar to those Edlebrock RPM's...a friend of mine wanted to build up a 455 Olds for his Cutlass..his goal was just a street engine and occasional trips down the track..he had already bought a Mondello cam that was considered hot for a hydraulic...forgot the lift numbers...the builder asked him how many ponies...my friend answers 450-500hp...no problem..
Edlebrock RPM's out of the box, .030 over with 9.5-1 compression, Ebrocks 2 plane intake...497hp on the dyno with a crappy carb...pump gas friendly..
just gave you that example on stock untouched Edlebrock RPM's....
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: smokinwoody] #1174534
02/08/12 10:52 AM
02/08/12 10:52 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I had a Mondello Hydraulic (ground by Engle BTW) in a 10.5:1 455 that I stuffed in a 77 Caddy Seville. Talk about a sleeper! iused to bust 5.0's and wave 'bye-bye' through the sunroof at them
But I agree a Performer RPM will easily make 600/600. Jeff at Modern has an excellent CNC program that uses a 2.19 intake (well recommended for a stroker) and flows IIRC around 320 with a big fat mid lift .250-.450 flow curve. Combined with a ported Holley Street Dominator and a 950-1000HP carb and a ~260/266@.050 .630 lift cam with wider 111-112 centers in around 107 would be better suited to a 4 speed by spreading the mid range torque out a bit compared to a tighter 108 and improve the hook/drivability. I guess my point is with the Max wedge ports available you can gain more power up top without sacrificing much if any in the lower ranges compered to a smaller higher velocity port. with a 4 speed taking a little grunt off the bottom and shifting it up the powerband might actually make the car easier to hook.
WIZE
In Car:
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174535
02/08/12 10:56 AM
02/08/12 10:56 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would go with the 440-1 cnc kit and try to make the compression 11.5 or even 12 to 1 with a bigger roller and you will still be able to use 93 octane gas. depending on the roller look at 700 hp and at least 550 to 600 ft lb.
Best thing about a 440-1 kit is it comes with everything you need! Everything!
Victors with max wedge port and CNC will also give that pop!
so kinda tomato tomato!
If exhaust clearance is an issue like in an A body go with max intake cnc ported EZ's
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Dodgem] #1174536
02/08/12 10:59 AM
02/08/12 10:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That said a Max wedge port CNC RPM head with a victor or 440-1 intake will get you there too. the max wedge port RPM does not flow much if any more than a stock port CNC but the max port intakes flow much better!
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Dodgem] #1174537
02/08/12 01:27 PM
02/08/12 01:27 PM
in the middle
dodger mope Online content
dodger mope  Online Content
in the middle
what rear ratio?
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: dodger mope] #1174538
02/08/12 05:01 PM
02/08/12 05:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I went with the Indy EZ heads on the 493 in my 63. I wanted 600 hp as I wanted to go 10's on pump gas thru the exh and it easily reached my goal. Bought my EZ heads from Dwayne Porter and he did some work on them for me. I use the Indy dual plane intake and it has 10.6 comp. 10.70's so far driving to and from the track has made me a happy camper. Ron
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: dodger mope] #1174539
02/08/12 05:03 PM
02/08/12 05:03 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
MW RPM/Stealth head with mopar 337 intake is the cheapest and easiest and will get you there no problem
EZ great value for the money
Victor and -1s more expensive but most potential and depending on if you have to buy Rocker arms anyway, this may be a route to look at
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: sixpackgut] #1174540
02/08/12 08:36 PM
02/08/12 08:36 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Will this need to fit under a stock hood? I am following this and want to make a few changes to my low deck 470 buy am limited with my stock hood.
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174541
02/08/12 09:11 PM
02/08/12 09:11 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
indy SR could make 650hp plus hp,with 500 plus inch motor you have. with stout solid roller. eddy head can get to 600 hp but dont think much room for improvement
MOPAR OR NO CAR
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: hemigod426] #1174542
02/09/12 11:32 PM
02/09/12 11:32 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
My 501 makes around 675 on pump gas with the 295 cnc lil ez's. 11.5 compression with a comp roller 268/276 @ .050 with the High Torque .440 lobes.Comes in around 190 psi cranking compression. Ran 10.22 on pump gas through the mufflers in my 67.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174543
02/10/12 04:13 AM
02/10/12 04:13 AM
Cab_Burge Online work
Cab_Burge  Online Work
600 HP on pump gas is not hard with a 505 stroker, Eddy RPM CNC and a good inatke and a 1050 domintor or a 4150 1000 HP carb will get you there easily, maybe a little more My bracket 505 made 687 on a Studka dyno at 2500 ft above sea level using race gas though, 12.5 to 1 comp. ratio. drop the compression to 10.5 or so with the same combination on pump gas will make 625 to 650 HP pretty easily See my post on my 518 dyno test this week PM me if you want
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Cab_Burge] #1174544
02/10/12 06:15 AM
02/10/12 06:15 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
S/Rs all the way
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: hemigod426] #1174545
02/10/12 09:10 PM
02/10/12 09:10 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Should I go Indy EZ/440-1, Perf RPM, Victor or Stealth [Re: Classic Car Guy] #1174546
02/11/12 01:36 AM
02/11/12 01:36 AM
Illinois
bad543dart Offline
bad543dart  Offline
Illinois
My motor is a 535 stroker with a set of box stock set of victors, roller cam, and 12.5 to 1 comp. It made 758hp@6500 and 728ft lbs@4300. When I was building the motor i talked to Dale Chenoweth of Chenoweth Speed and Machine and he said there was little to no difference between the Indys and the Victors. I also ran the stealths on the previous moter which was also a 535 with 10 to 1 and a solid cam and that motor ran 6.90 in the 1/8 in a 69 dart and those heads were also straight out of the box, no port work. So any of the heads will get you there but the stealth can with a port job and they are alot cheaper. It just depends on the future upgrades that you are planning and buget. You could also save $$$ with the stealths due to not having to have the offset rockers and lifters but the will need a good port job.
