Head Gasket #1173269
02/06/12 12:11 PM
02/06/12 12:11 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Replacing intake manifold and the metal tabs from the head gasket are still in place. Any reason these should be left?
Thanks!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Head Gasket [Re: 36PLYM] #1173270
02/06/12 12:12 PM
02/06/12 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what engine ?
Re: Head Gasket [Re: JohnRR] #1173271
02/06/12 12:17 PM
02/06/12 12:17 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
318 with 340/360 J heads
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Head Gasket [Re: 36PLYM] #1173272
02/06/12 12:49 PM
02/06/12 12:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The little tabs were used to help locate the cork end seals, that alot of folks replace with just silicone, which the tabs don't help with.
