Re: My Budget 440 Build (Learning Experience)
[Re: His and Her 69's]
#1171676
04/07/12 07:53 PM
04/07/12 07:53 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I took a chance and brought the flywheel to have resurfaced to see what happened. It came out perfect, and he didn't have to take that much off. Thanks for your help! ![](/ubbthreads/images/graemlins/thumbs.gif) Today I also installed the harmonic balancer, fuel pump and primed the oil pump. I got about 50lbs at the gauge (it was still going up but my drill was smoking, so I stopped), so I'm happy. Next, I need to install the intake, flywheel & clutch. So far, so good ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: bobs66440]
#1171684
04/19/12 10:22 PM
04/19/12 10:22 PM
Posts: 1,300 Washington
19cuda73
Washington
Great Job! Nice work! You'll love that Centerforce. It is the best choice!!!
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: bobs66440]
#1171689
05/01/12 10:57 PM
05/01/12 10:57 PM
I've had engines built for me but by far the most rewarding experience has been building a couple of mild 440's myself. It's like giving birth for us males! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: mickm]
#1171692
05/02/12 04:06 PM
05/02/12 04:06 PM
bobs66440
it may just be the picture, but it really looks like there is a hole in the header where you massaged it for the power steering pump?
You're right, it does but that's just a tack weld where the id plate was welded. I had to remove it to heat the area to dimple it. I was just lazy and didn't grind them off ;-). Thanks.
