Re: What spark plugs do you like?
[Re: RapidRobert]
#1169597
02/01/12 11:02 PM
02/01/12 11:02 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Best plug I have used so far is Denso iridium plugs,always have liked NGK or Denso plugs in every engine. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1169598
02/01/12 11:19 PM
02/01/12 11:19 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
You have got to be joking ! Someone who thinks Bosch are OK? Those are the worst plugs I have ever seen! By far! I am a full time mechanic and have been for the last 15 years and have seen sooooooooo many people do there own tune-up and bring us the car a week later and want to know why it runs worse than it did with 100,000 mile (any brand)old plugs, %99 of the time it is because they put some Bosch plugs of some sort in it. I only remember that happening one time and it was not a Bosch, it was an autolite. Personally I like NGK or Denso and every engine works fine with them, either a company makes good plugs or they don't, just like oil filter companies make good filters (everything but Fram) or they don't(Fram). I see no middle ground in either product. Really good advertising and crappy products or vise versa, that is the same reason you see so many Fords on the road, good advertising crappy product. We install NGK as a standard practice in my shop and have never had a comeback for them.
[Re: dOc !]
#1169603
02/02/12 12:53 PM
02/02/12 12:53 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Hot Rod Dave I agrre with you 110%.Bosch are total junk.I cant count how many I replaced at work because they were missing.My buddy put a set that were like 8 bucks each in his old Buick.I replaced them with ACs and it eliminated the miss he had.They were like a month old.Ive probally replaced a few thousand in the last 30 years because they are junk.My kid put a set in a 61 Polara BB we had.Rant them for like 3 months.Wouldnt start and always didnt idle smooth.I put a set of Autolites in and it fired right up and smoothed out.Rocky
Chrysler Firepower
[Re: therocks]
#1169604
02/02/12 01:44 PM
02/02/12 01:44 PM
Posts: 5,170 CT
GTX MATT
CT
I prefer the Champions. I tried Autolites once when there was a thread like this and the consensus seemed to be that Autolites were better but the car did seem to run better with the Champions. I know that as long as the heat range is the same it should not matter, but the Champions just seemed to idle cleaner and had sharper response. Also the Champions dont turn all rust colored like the Autolites and they are easier to read because they are nickel plated or whatever they, instead of black oxide coated like the Autolites. On another note I will say CHAMPIONS DO NOT SWIM! If you foul them they WILL NOT WORK RIGHT EVER AGAIN! I've fouled Autolites and they will work, just not well. Ive fouled Champions and the engine just flat out refuses to run. ![](/ubbthreads/images/graemlins/hammer.gif)
