Re: Indy BB head data [Re: AndyF] #1168235
02/08/12 12:33 AM
02/08/12 12:33 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Yes please do show AndyF's head numbers. It would be nice to see them in the same thread for easy comparison. Especially since this one is for the archives. Absolutely great post.
Thanks Dwayne
Damon
Re: Indy BB head data [Re: fast68plymouth] #1168236
02/08/12 05:01 PM
02/08/12 05:01 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Thanks for the great info Dwayne. I'll keep this in mind for sure.
Re: Indy BB head data [Re: cudarex] #1168237
07/25/12 11:24 PM
07/25/12 11:24 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
i did a set of SR CNC295's a couple months ago.....figured i'd add them to the list here....
the exhaust was actually pretty weak OOTB on this particular set, but came around with some tweeking.
same cylinder for both tests.....a true "before and after" test.
Intake ports:
A- as delivered from Indy
B- PRH valve job, back cut valve, blend valve job into bowl and chamber
lift----A/B
.100--66.7/74.3
.200-142.7/150.1
.300-213.5/219.6
.400-269.3/275.6
.500-307.4/314.6
.550-322.4/329.9
.600-335.5/342.2
.650-343.0/351.6
.700-349.7/359.0
.750-356.0/360.9
Exhaust ports:
C- as delivered from Indy
D- PRH valve job, back cut valve, blend valve job into bowl and chamber
no flow tube for either test
lift----C/D
.100--53.0/58.5
.200-104.2/114.6
.300-146.8/164.7
.400-177.3/203.4
.500-198.1/232.4
.550-207.6/243.8
.600-217.9/253.4
.650-224.8/263.7
.700-230.5/272.4
.750-235.1/270.5
Re: Indy BB head data [Re: fast68plymouth] #1168238
07/26/12 10:00 AM
07/26/12 10:00 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is it Indy's VJ that sucks? the backcut that really helps? the chamber and bowl blend or combo of all 3 that makes such a big difference?
Re: Indy BB head data [Re: sixpackgut] #1168239
07/26/12 01:53 PM
07/26/12 01:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
I had never seen this before, this needs to be in the tech archives or best of as well.
Thank you Dwayne!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Indy BB head data [Re: fast68plymouth] #1168240
07/26/12 03:50 PM
07/26/12 03:50 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Wow, it really woke up the ex. side. Thanks for the info Dwayne.
