Re: Indy BB head data
[Re: AndyF]
#1168235
02/08/12 12:33 AM
02/08/12 12:33 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello, Yes please do show AndyF's head numbers. It would be nice to see them in the same thread for easy comparison. Especially since this one is for the archives. Absolutely great post. Thanks Dwayne Damon
[Re: cudarex]
#1168237
07/25/12 11:24 PM
07/25/12 11:24 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i did a set of SR CNC295's a couple months ago.....figured i'd add them to the list here....
the exhaust was actually pretty weak OOTB on this particular set, but came around with some tweeking.
same cylinder for both tests.....a true "before and after" test.
Intake ports: A- as delivered from Indy B- PRH valve job, back cut valve, blend valve job into bowl and chamber
lift----A/B .100--66.7/74.3 .200-142.7/150.1 .300-213.5/219.6 .400-269.3/275.6 .500-307.4/314.6 .550-322.4/329.9 .600-335.5/342.2 .650-343.0/351.6 .700-349.7/359.0 .750-356.0/360.9
Exhaust ports: C- as delivered from Indy D- PRH valve job, back cut valve, blend valve job into bowl and chamber
no flow tube for either test
lift----C/D .100--53.0/58.5 .200-104.2/114.6 .300-146.8/164.7 .400-177.3/203.4 .500-198.1/232.4 .550-207.6/243.8 .600-217.9/253.4 .650-224.8/263.7 .700-230.5/272.4 .750-235.1/270.5
[Re: fast68plymouth]
#1168238
07/26/12 10:00 AM
07/26/12 10:00 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is it Indy's VJ that sucks? the backcut that really helps? the chamber and bowl blend or combo of all 3 that makes such a big difference?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1168239
07/26/12 01:53 PM
07/26/12 01:53 PM
Triple Threat
Renton Washington
I had never seen this before, this needs to be in the tech archives or best of as well.
Thank you Dwayne!
