Replacement rear springs #1167408
01/28/12 07:53 PM
01/28/12 07:53 PM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Who makes the most correct looking resto rear spring for a '69 b-body,
looking at the 426/440 type? And if the interliners
between the leaves are used and the correct clamps,number of clamps.
Re: Replacement rear springs [Re: demonH1B] #1167409
01/29/12 03:05 PM
01/29/12 03:05 PM
North Carolina
Tadams Offline
Tadams  Offline
North Carolina
I ordered mine my my Barracuda Formula S and am well pleased. Price was good, shipping was fast and from what I know they are identical to the factory ones I took off. If you call and talk they will answer all of your questions.
Re: Replacement rear springs [Re: Tadams] #1167410
01/29/12 03:13 PM
01/29/12 03:13 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
form who?
Re: Replacement rear springs [Re: 05dakota] #1167411
01/29/12 03:47 PM
01/29/12 03:47 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Eaton Spring, you will have to reshape the bottom spring on both springs to round one end, or replace with original bottom spring for the part numbers.
logan426
Re: Replacement rear springs [Re: Tadams] #1167412
01/29/12 03:51 PM
01/29/12 03:51 PM
North Carolina
Tadams Offline
Tadams  Offline
North Carolina
Sorry, Springs and Things
Re: Replacement rear springs [Re: Tadams] #1167413
01/30/12 11:20 AM
01/30/12 11:20 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
You don't have to be sorry I'm happy with Eaton your happy with springs and things. I know from my judgement the Eatons look good.
logan426
Re: Replacement rear springs [Re: MLR426] #1167414
01/30/12 01:46 PM
01/30/12 01:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
logan426
Sometimes it seems nobody reads these things.
I have mechanical Aptitude.
I can screw up anything.
