Re: aren't they pretty, winter upgrade. [Re: pittsburghracer] #1167331
01/29/12 11:04 AM
01/29/12 11:04 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Bill I have used 3 sets over the years and really like them but do yourself a favor and dummy them on the heads as soon as you can to see if they need some clearancing for the valve springs. Some guys send them back so T&D can do the work or you may lose the warranty if you do it yourself.
Thanks for the heads up, Terry is going to take care of that because the heads need to be cut anyways for tip alignment and height they appear that they will fit but would be too close for comfort so the intent is to use a smaller diameter spring to get a little more clearance, would be going from a 1.625 dia to a 1.550.
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167332
01/29/12 11:27 AM
01/29/12 11:27 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Bill...way too PERRRTY to hide inside a valve cover!
Re: aren't they pretty, winter upgrade. [Re: Labratt] #1167333
01/29/12 12:19 PM
01/29/12 12:19 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Yeah,,no kidding,need to be painted the same color as the green on many many dollar bills.
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167334
01/29/12 01:27 PM
01/29/12 01:27 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
thts purty Bill
Re: aren't they pretty, winter upgrade. [Re: 340RICK] #1167335
01/29/12 01:37 PM
01/29/12 01:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I can you this..It ain't about money if it fix the problem.It was down right crazy at times.and very frustrating..To win a round and not be able to go run the next one.. He got a box of junk parts over this deal ! Never in my life seen a deal like this..You never knew when it was going to break..it might go 6-8 rounds and be OK and then it would break 3 rounds in a row ! valve cover bolts are wore out on that car !
Re: aren't they pretty, winter upgrade. [Re: 340RICK] #1167336
01/29/12 01:40 PM
01/29/12 01:40 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I have Jesel rockers on my 540. I never (ever) worry about valvetrain failure anymore. You will love the peace of mind that setup will give you.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: aren't they pretty, winter upgrade. [Re: VernMotor] #1167337
01/29/12 04:53 PM
01/29/12 04:53 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Thanks Rick! You are sooooo right Vern, it was exasperating at times, be going some rounds heading for a good showing and then... poof and a mad dash under the hood to try and fix it, not so bad during time trials where I had some time,,,but getting close to round robin racing...
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167338
01/29/12 09:58 PM
01/29/12 09:58 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Bill..what set-up were you running??
Re: aren't they pretty, winter upgrade. [Re: Labratt] #1167339
01/29/12 11:39 PM
01/29/12 11:39 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
1.6 Erson's,,,they don't make them anymore.
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167340
01/30/12 12:07 AM
01/30/12 12:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill.. what head are you using... still the commando...
I put the TDs on my W-5s for the Rampage and I cut
(if memory is right) .180 off the bases... but the
W-5 doesnt have the cradle... just a flat pad....
by the way... love the TD stuff
Re: aren't they pretty, winter upgrade. [Re: MR_P_BODY] #1167341
01/30/12 12:38 AM
01/30/12 12:38 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
going on the commandos, kinda neat that they sent a gage with the rocker's to measure the stand height and has instruction's on how to do it.
Re: aren't they pretty, winter upgrade. [Re: nhramark] #1167342
01/30/12 01:00 AM
01/30/12 01:00 AM
Arizona
Chris'sBarracuda Offline
Arizona
I broke a T&D intake yesterday..
Chris..
Re: aren't they pretty, winter upgrade. [Re: Chris'sBarracuda] #1167343
01/30/12 01:04 AM
01/30/12 01:04 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Chris..
when did they make them in blue? looks like a mopar performance rocker from here.
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167344
01/30/12 01:07 AM
01/30/12 01:07 AM
Arizona
Arizona
Chris..
T&D's all used to be blue, but now they look like Jesels..
My Exhausts are like that..
Chris..
Re: aren't they pretty, winter upgrade. [Re: dartman366] #1167345
01/30/12 01:08 AM
01/30/12 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris..
... I dont see where the bearing was
Re: aren't they pretty, winter upgrade. [Re: MR_P_BODY] #1167346
01/30/12 01:19 AM
01/30/12 01:19 AM
Arizona
Arizona
Chris..
Look closer.. Intake #5..
Chris..
Re: aren't they pretty, winter upgrade. [Re: Chris'sBarracuda] #1167347
01/30/12 01:24 AM
01/30/12 01:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They must be pretty old... all of mine are natural
color and I've have multiple sets for about 12 years
Re: aren't they pretty, winter upgrade. [Re: MR_P_BODY] #1167348
01/30/12 02:01 AM
01/30/12 02:01 AM
Arizona
Arizona
I have a set of new 1.8 B1 T&D's that I got about 5 years ago.. They are blue..
Chris..
Re: aren't they pretty, winter upgrade. [Re: Chris'sBarracuda] #1167349
01/30/12 03:25 AM
01/30/12 03:25 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Chris,
That looks like a Mopar rocker not a T&D. The T&D's have needle bearings on the shaft mount rockers and the paired shaft ride on a 5/8" shaft with bearings as well. If you are running over 600# of spring pressure you should have the paired shaft rockers.
Just to make sure you should call T&D and ask for Sheldon he can tell you exactly what they are and when they were built just so you know.
1(775)884-2292
