Gas leak
#1167258
01/28/12 04:57 PM
01/28/12 04:57 PM
Posts: 304 Ohio
LS-300
Ohio
Ok I need help figuring out a gas leak. Car is a 70 Cuda 426 2 4-barrel. Problem is after driving around and parking a puddle of fuel can be seen behind the car like fuel coming out the filler neck. Not just a couple of drops but about 1/2 a cup or more. Filler tube is new so it shouldn't be it. What gives?
1979 Chrysler 300
1968 Barracuda project
Re: Gas leak
[Re: mcmopars]
#1167261
01/28/12 08:09 PM
01/28/12 08:09 PM
Posts: 304 Ohio
LS-300
Ohio
The entire car was redone at one time and the fuel system was supposed to be completely rehabbed as well. Don't have the car here with me to look but the leak looks to be coming from close to the cap. Is this where the vent line connects?
1979 Chrysler 300
Re: Gas leak
[Re: LS-300]
#1167262
01/28/12 08:15 PM
01/28/12 08:15 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
No, the vent line is on the top/passenger side. The fill tube is behind the plate though, and sealed to the tank with a big grommet-type seal. It could very well be that.
Re: Gas leak
[Re: Pacnorthcuda]
#1167263
01/28/12 11:10 PM
01/28/12 11:10 PM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
Wasn't there a bad run of filler tube seals a few years ago? One could have found its way onto this car.
Re: Gas leak
[Re: JDMopar]
#1167264
01/29/12 02:16 PM
01/29/12 02:16 PM
Posts: 304 Ohio
LS-300
Ohio
Thanks guys! When it warms up a bit I'll have to take a short ride then crawl under to find exactly where leak is originating. Didn't know about the bad run of seals. Car was redone about 5 years ago.
1979 Chrysler 300
