Page 2 of 4 1 2 3 4
Re: its winter...so how about a "what will it make" post... [Re: 383man] #1166421
01/28/12 02:18 PM
01/28/12 02:18 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Ok for an actual guess I'd say 680-700. I think the hp numbers will look low because of the displacement (peak torque at a lower rpm).
Re: its winter...so how about a "what will it make" post... [Re: 383man] #1166422
01/28/12 02:27 PM
01/28/12 02:27 PM
Delray beach, Florida
P
Performance Only Offline
P
665 hp 720 tq
machine shop owner and engine builder
Re: its winter...so how about a "what will it make" post... [Re: firefighter3931] #1166423
01/28/12 02:34 PM
01/28/12 02:34 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I've seen the car run and it leaves real hard (3-4ft wheelstands) and 60fts very well for the weight. You'll be surprised at the power numbers VS ET's for this beast.
I know what it made so i can't play
Ron
does the ET of the car equal the HP numbers on wallce or morosso slide?
Re: its winter...so how about a "what will it make" post... [Re: sixpackgut] #1166424
01/28/12 02:57 PM
01/28/12 02:57 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
690hp Dave
Re: its winter...so how about a "what will it make" post... [Re: sixpackgut] #1166425
01/28/12 03:00 PM
01/28/12 03:00 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Ron
Using the Wallace calculator the numbers are off. Wallace indicates that it's making more power for the ET than what it did on Dwayne's dyno. Using Wallace as a reference point this combo would fall into the "overachiever" category.
Ron
Re: its winter...so how about a "what will it make" post... [Re: sixpackgut] #1166426
01/28/12 03:11 PM
01/28/12 03:11 PM
gregsdart Offline
gregsdart  Offline
This is a tough one, but going by my deal with the same head work roughly, I will guess 725 hp to 700 at 6600 rpm depending on dyno with a peak torque around 4800 rpm. Your dyno numbers have always produced excellent ETs for the numbers, so that is why I qualified it at possible 700 hp. I also figure this package will carry ninety five percent of peak hp from 5200 to over 6900 rpm. All in all, a package i would like to have in my other 65 dart!
Glad to see you on the board, Dwayne!
Re: its winter...so how about a "what will it make" post... *DELETED* [Re: gregsdart] #1166427
01/28/12 04:28 PM
01/28/12 04:28 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Post deleted by TheBlackCar
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166428
01/28/12 04:59 PM
01/28/12 04:59 PM
actually....more like a "what did it make" post.
its a motor i did for a friend of mine last spring.
some of you already know the numbers......so you guys cant play
the plan was for a relatively low RPM BB that would run on mixed gas, and be low maintenance, and run 10.0's at 3450lbs in the summer heat.
the original plan was going to be based on a stock 440 block bored .030 over with a 4.250 crank, for 505ci.
then, the decision was made to use an aftermarket block.
once that decision was made, then it didnt really make sense to stay with 505ci.
i decided on a 4.440 bore with a 4.375 stroke.....542ci.
then, it was deemed worth the extra $$$ to lose the 150lbs by using an aluminum block rather than a heavyweight World iron piece(over 300lbs).
so, its an Indy block, 4.440 bore
*eagle 4.375 crank
*eagle 7.100 rods
*custom Diamond inverted dome pistons, 11.7cr
*plain, old, boring 1/16, 1/16, 3/16 ring pack, std tension oil rings
*EZ-1 heads, chambers ported, bowls blended, valve job, flow 340/230
*roller cam, 272/278-112, .650/.630 lift
(the heads and cam actually were used parts that came from Mark Gates 511 Pacer motor)
*HS 1.5 rockers
*older, non-HP 1050 3 circuit dominator(also from Marks 511)
*440-3 intake
*Hooker 1 7/8" fenderwell headers(long), 3.5" collectors
*center sump deep pan with single line external system
then.....its going in a 3450lb Dart with ladder bars and 30X10.5 radial drag slicks, 4.10 gears and an ATI 8" converter.
lets hear what you got to say.....
OK, Dwayne, Fess up, what did it make?
Re: its winter...so how about a "what will it make" post... [Re: TheBlackCar] #1166429
01/28/12 11:03 PM
01/28/12 11:03 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
okay....here we go.....
when i was putting this motor together i told the customer it "should make somewhere around 700hp with my dyno headers.....and it will probably lose 40-50hp with the car headers".
first sheet.....2-2 1/8 X 4 dyno headers
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166430
01/28/12 11:04 PM
01/28/12 11:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
and with the car headers....
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166431
01/29/12 12:00 AM
01/29/12 12:00 AM
NC
440Jim Offline
440Jim  Offline
NC
Dwayne, you called that one pretty close.
542 CID, EZ-1 Heads
717.7 hp at 6000 rpm, 677.1 ft-lb at 4500 rpm, 2-2 1/8 X 4 dyno headers (stepped)
678.0 hp at 5900 rpm, 673.3 ft-lb at 4500 rpm, Hooker 1 7/8" fenderwell headers(long)
39.7 hp difference. Time for some new car headers
I bet even the Hooker A-body 2" fenderwells (~43" long) would be 30 hp short of the 2 to 2-1/8 stepped headers.
One more thing, with all that torque at 4500 rpm, it might push the 8" converter stall and shift recovery rpm higher than he expects.
Re: its winter...so how about a "what will it make" post... [Re: 440Jim] #1166432
01/29/12 12:39 AM
01/29/12 12:39 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Very nice build Dewayne. And as Greg stated good to see you here again.
PS: How is Mark Gates I miss his posts as well.
Re: its winter...so how about a "what will it make" post... [Re: 440Jim] #1166433
01/29/12 12:53 AM
01/29/12 12:53 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I didnt have time to reply earlier , but I figured around 750 hp with decent headers and around 700 hp with the long fenderwells.
What did the car ET at. I bet around 9.20/9.40s or so.
Re: its winter...so how about a "what will it make" post... [Re: Sport440] #1166434
01/29/12 01:09 AM
01/29/12 01:09 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
39 Hp up top but look at the torque advantage of the small tubes at 3900 rpm that's 67 Hp in favor of the small tubes! A heavy combo with the right gear and vert probably could et as well or better even if the top end mph wound up lower.
All out race car big headers no doubt....but If this motor was in a heavy dual Purpose car I'd opt for the roll on grunt....That's really not enough head and rpm up top to warrant that big a header unless it was a real light car. Peak torque isn't that much better like a bigger head flow would bring. Maybe an off the shelf 2" x 3 1/2 would be the best balance for this one. And with a full exhaust the peak to peak would likely be less of a spread.
Still an impressive motor!! Like I said I knew the Torque would be massive.
WIZE
In Car:
Re: its winter...so how about a "what will it make" post... [Re: Streetwize] #1166435
01/29/12 01:47 AM
01/29/12 01:47 AM
P
P
i was only off by 8 HP but missed the torque on a quick guess it would be higher with the smallish cam, heads and headers.
i do find it interesting though reading some of the other guesses puttinbg a combo like that in the 750-820 hp range. just makes me wonder what the guesses were based on.
thanks for sharing,
Re: its winter...so how about a "what will it make" post... [Re: Performance Only] #1166436
01/29/12 02:32 AM
01/29/12 02:32 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
How much more HP would it of made if the comp was 13.5:1?
Just Curious
Kevin
Re: its winter...so how about a "what will it make" post... *DELETED* [Re: Performance Only] #1166437
01/29/12 02:50 AM
01/29/12 02:50 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166438
01/29/12 04:36 AM
01/29/12 04:36 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How are those Indy blocks these days ..... leaks fixed?? ...and at what power level does the block start moving-around? And what do they get for the blocks these days?
Re: its winter...so how about a "what will it make" post... [Re: TheBlackCar] #1166439
01/29/12 10:47 AM
01/29/12 10:47 AM
tboomer Offline
tboomer  Offline
Head flow and Dyno #'s are nice to talk about, but what's it run?
That is the only thing that matters in my opinion. After all, thats what those tools are intended for, making a more efficient race car, right?
So, whats it run? Maybe you're waiting to share the ET info to leave a few scratchin their heads??? Is that why the post had info about the car included?
That is a good question! It is a well thought out combo indeed! And I was way off on my guess!! What does he shift at,Dwayne and cross the stripe at?
Re: its winter...so how about a "what will it make" post... [Re: tboomer] #1166440
01/29/12 10:58 AM
01/29/12 10:58 AM
Ontario,Canada
Ontario,Canada
What do you guys think it ran based on the 3450 raceweight and dyno results posted with the 17/8 long tube headers ?
In other words ; how fast would you expect a 680hp combo to go at 3450 lbs
Ron
Page 2 of 4 1 2 3 4
