Re: MSD or Not
[Re: DANA60]
#1166074
01/29/12 03:59 PM
01/29/12 03:59 PM
I run the 6AL mainly because I like to eliminate the ballast resistor, love the rev limiter function, and I got tired of replacing bad ECU's. I only get about 2-3 years out of the current parts store ECU's in my truck before they crap out!
The great thing about the MSD is you can add on things like a two step or adjustable timing module so you can control timing from the drivers seat, It really does idle nice compared with points.
I rebuild and tailor the older Mopar electronic distributors to use with the MSD. All it is is a triggering device anyway. Some of them do have reluctors that aren't quite right and I've found you have to go through a few to set a consistent air gap.
Re: MSD or Not
[Re: jeff57]
#1166076
01/30/12 10:01 AM
01/30/12 10:01 AM
Posts: 1,515 AZ
Mike P
AZ
The amount of benefit you get from an MSD really depends on the engine you attach it to. On you’re 440 Cuda I think you would probably see a bit of improvement in starting and cold idle but if it’s enough to justify the changeover is up to you. Here are a few thoughts for what they are worth.
In most cases with a stock low performance engine you spend a fair amount of money to hang an ugly box (sometimes 2 if you’re running a factory tach that requires the add on tach adaptor) and wiring in the engine compartment for no noticeable gain.
Although MSD boxes have a pretty good reputation for reliability, if you happen to be away from home and the box dies you’re dead in the water until you can find a replacement which may not be that easy in a lot of small towns.
That being said they can make a BIG difference on cars with a lot of cam, cold start issues, or cold drivability issues (for instance on cars that have had the intake exhaust crossover blocked).
Of the 7 car I own, I’ve use MSDs on 2 of them...... the other 5 don’t need it.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: MSD or Not
[Re: jeff57]
#1166078
01/30/12 02:25 PM
01/30/12 02:25 PM
Posts: 1,380 Back In Iowa
belv2vert66
Back In Iowa
i used a pertronics igniter in my 69 dart 340 because it hides well,installs easily,very dependable and cost effective.great piece for a driver. jeff57
This is what I run also. I kept my ballast on the fire wall so things look somewhat factory. Just gutted it and replaced the resistor with a heavy gauge wire
Re: MSD or Not
[Re: 300_dup5]
#1166079
01/30/12 02:26 PM
01/30/12 02:26 PM
Posts: 489 NE
bigtail
NE
Just a weekend cruzer, Getting to old to drive it hard been there, just like a nice looking car
For just being a weekend driver, MSD is a lot of wasted money and overkill. Stock Mopar electronic distributor should be more than you ever need, and a good set of wires and plugs. Plus replacement parts are readily available, as noted. A 100,00 volt coil is useless if your engine only requires 15,000 volts. The electrical system will only draw what it needs, no more. ie, a 100,000 volt coil will almost certianly NEVER ever, truly deliver anywhere that amount. Unless you gap your plugs 1/2"
This page is made up completely of recycled electrons.
Re: MSD or Not
[Re: JohnRR]
#1166080
01/30/12 02:26 PM
01/30/12 02:26 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
pertronics under the stock cap ??
or convert to chrysler setup
Re: MSD or Not
[Re: 70Cuda383]
#1166081
01/30/12 09:22 PM
01/30/12 09:22 PM
See, I'm of the opposite opinion.
Most small town parts stores (O'Reilly's for example) stock the 6A ignitions because even the blue oval and bowtie boys use them. It's getting harder to find a place that has Mopar ECU's in stock!
Re: MSD or Not
#1166082
01/30/12 09:32 PM
01/30/12 09:32 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I just left my orange box on the firewall and wired up the MSD with spade connectors on all of the connections formerly used by the orange box. Easy to switch back if it ever dies on me on the road.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: MSD or Not
[Re: Secret Chimp]
#1166083
01/30/12 10:41 PM
01/30/12 10:41 PM
Posts: 1,515 AZ
Mike P
AZ
“……I just left my orange box on the firewall and wired up the MSD with spade connectors on all of the connections formerly used by the orange box. Easy to switch back if it ever dies on me on the road…..”
I went one better when I wired my 57. I mounted both the MSD and Chrysler box and when I built the wiring harness used 9 pin plugs so that if needed I could just unplug the harness with the MSD and plug in the Chrysler box.
The Plymouth is my vacation car (usually 4000+ mile trips) and I’ve never had to change it, (although I do plug in the Chrysler box to check it before I go on long road trips) but it is just kind of nice having the peace of mind knowing that I have a backup to the MSD.
