Page 3 of 4 1 2 3 4
Re: i'm bored with the six pack [Re: Ari440] #1165507
01/27/12 12:51 AM
01/27/12 12:51 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
We had to add 100 lb for the 10.04 run at Atco because we didn't want to risk the points hit at the last race if they bounced us. It's just the 440-25 bathtub. Has a bit more in it.
need to resize pic
Re: i'm bored with the six pack [Re: Kevins493] #1165508
01/27/12 01:02 AM
01/27/12 01:02 AM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
need to resize pic
thank you
how tall is the manifold ?
do you have a side pic ?
how much dos that manifold go for ?
1.39 9.85 - 137 mph
Re: i'm bored with the six pack [Re: Cab_Burge] #1165509
01/27/12 03:13 AM
01/27/12 03:13 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Tell all them doubters to get lost, there jealous because they don't have the fortitude and determination to make odd ball stuff work anybody can make a single four barel work, some can even make two four barrels work, but it takes a real genuis to make three two barrels work It takes a super genuis to make eight two barrels work, maybe that is the real diffenition of a idiot Sixpaks forever
A wise man once said............
Re: i'm bored with the six pack [Re: MoparDonny] #1165510
01/27/12 03:26 AM
01/27/12 03:26 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
i have made a decesion......
i can sleep now
Re: i'm bored with the six pack [Re: sixpackgut] #1165511
01/27/12 03:28 AM
01/27/12 03:28 AM
Arizona
Chris'sBarracuda Offline
Arizona
Goodnight..
Chris..
Re: i'm bored with the six pack [Re: Chris'sBarracuda] #1165512
01/27/12 06:02 AM
01/27/12 06:02 AM
Sweden
ppmracing Offline
ppmracing  Offline
Sweden
Go for the six pack,
If you have the carb dont trow them away.We have been using six pack carbs on stock engine race engines and 572 cu stroker engines, and the work awesome. But their is some work and magic that can be done and help out the tuning.
Good luck
Re: i'm bored with the six pack [Re: 383man] #1165513
01/27/12 10:04 AM
01/27/12 10:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
This 440 Super Bee runs one on it. He has run 10.40's and it is an Indy motor. He says he likes it alot. I cant seem to find any info on it for the bigblock wedge motors. Ron
http://www.hotrodhotline.com/feature/2011show/east_coast_indoor_nats_2011_al/html/page_7_82.php
That car is tight. I've seen him run. It's a 4 speed too I think.
Coming soon!!!!
Re: i'm bored with the six pack [Re: Mr.Yuck] #1165514
01/27/12 11:27 AM
01/27/12 11:27 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Ray, Im just stepping into the fire. Im putting a stock set up on the 440 in the Ramcharger. Basically bone stock, but for a guy like me who can screw up just about anything, a learning curve is gonna hit me like a ton of dominators. Im basically doing it for the "cool" factor, and some performance. To be honest I was planning on contacting you on Facebook for some basic tuneing advice, and if you switch everything up, you might loose your sharpened skills on the multi carb set ups, and I would be lost for ever LOL.
Have you talked with Quick77R/T? He has a mod man with a sixpack on a small block stroker and a lot of extra juice plumbed to it as well.
Kasey
Re: i'm bored with the six pack [Re: Moparnut426] #1165515
01/27/12 11:54 AM
01/27/12 11:54 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Hey Casey...
Yep Rays (SPG) has been a big help in some small ways on my six pack doings.
Ray, ive a BB mod man match ported to the bigger felpro gasket you can play with if you dont mess with the ports. Even got a top plate for the mech carbs.
This is with the added spacer on mine....so far so good, it ran good with the carbs set back to base line settings, adjusted back to old specs, ran perfect.
Only one vid from this install on this A12 car...Seems like they had some bugs to work out....but no more vids then this one..
http://www.youtube.com/watch?v=hAXRJKCuUxo
Re: i'm bored with the six pack [Re: Moparnut426] #1165516
01/27/12 12:01 PM
01/27/12 12:01 PM
Charleston
Charleston
Kasey
my six pack wont fit on the mod man. the plenum is not long enough. yes, i talk to quick and another guy regularly with six packs on mod man and they both seem to like the intake but they had a stock intake before
Re: i'm bored with the six pack [Re: sixpackgut] #1165517
01/27/12 12:06 PM
01/27/12 12:06 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Yep, im sure they might be a better intake for the BB cars, but for the money??? Who knows.
For the small block people its oem, or the mod man or bump it up to a sheet metal.
I will say the oem small block high rise dual plane is a good intake for oem.
I have several top plates Ray, if your mech carbs all have metering plates/blocks they will fit....Let me dig a pic of the plate with manual carbs.
Re: i'm bored with the six pack [Re: sixpackgut] #1165518
01/27/12 03:19 PM
01/27/12 03:19 PM
long island NY
long island NY
i can sleep now
what are you going to use ?
1.39 9.85 - 137 mph
Re: i'm bored with the six pack [Re: Ari440] #1165519
01/27/12 03:38 PM
01/27/12 03:38 PM
Charleston
Charleston
2 650 avs carbs on my sheetmetal ram
going to dyno the six pack vs the sheetmetal ram and maybe if someone will lend me a single intake i could dyno with a single Dom also
Re: i'm bored with the six pack [Re: sixpackgut] #1165520
01/27/12 03:42 PM
01/27/12 03:42 PM
Delray beach, Florida
P
Performance Only Offline
P
i think i've got 3 old rochester two barrels from an old 409 if you want to try that on the mod man. those ought to fit.
machine shop owner and engine builder
Re: i'm bored with the six pack [Re: Performance Only] #1165521
01/27/12 03:55 PM
01/27/12 03:55 PM
Charleston
Charleston
i'm also looking for a new engine builder/machinest
Re: i'm bored with the six pack [Re: LaRoy Engines] #1165522
01/27/12 08:00 PM
01/27/12 08:00 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I like reading your posts 'gut! Would you have to change your handle to 2Pac Gut? It doesn't have the same ring to it, plus I'm not too much of a 2Pac fan
How about a stock magnum intake? Beer-keg Gut! I'm down with that, but ultimately it's your decision...
Re: i'm bored with the six pack [Re: sixpackgut] #1165523
01/27/12 09:55 PM
01/27/12 09:55 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I have a team G std port dominator intake I bought from Dwayne you could use on the dyno.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: i'm bored with the six pack [Re: sixpackgut] #1165524
01/27/12 10:25 PM
01/27/12 10:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: i'm bored with the six pack [Re: Ari440] #1165525
01/31/12 11:46 PM
01/31/12 11:46 PM
Charleston
Charleston
i can sleep now
going to give this a try. will use these carbs on the gen 3 hemi. got to get some new top plates made for both intakes
Re: i'm bored with the six pack [Re: sixpackgut] #1165526
01/31/12 11:50 PM
01/31/12 11:50 PM
long island NY
long island NY
i can sleep now
750s?
1.39 9.85 - 137 mph
Page 3 of 4 1 2 3 4
