Re: i'm bored with the six pack
[Re: Ari440]
#1165507
01/27/12 12:51 AM
01/27/12 12:51 AM
Posts: 2,379 MD
Kevins493
MD
We had to add 100 lb for the 10.04 run at Atco because we didn't want to risk the points hit at the last race if they bounced us. It's just the 440-25 bathtub. Has a bit more in it. need to resize pic
[Re: Cab_Burge]
#1165509
01/27/12 03:13 AM
01/27/12 03:13 AM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
Tell all them doubters to get lost, there jealous because they don't have the fortitude and determination to make odd ball stuff work anybody can make a single four barel work, some can even make two four barrels work, but it takes a real genuis to make three two barrels work It takes a super genuis to make eight two barrels work, maybe that is the real diffenition of a idiot Sixpaks forever
A wise man once said............
[Re: MoparDonny]
#1165510
01/27/12 03:26 AM
01/27/12 03:26 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i have made a decesion......
i can sleep now
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Moparnut426]
#1165515
01/27/12 11:54 AM
01/27/12 11:54 AM
A57_RT
Parts Problem
Parts Problem
Hey Casey... Yep Rays (SPG) has been a big help in some small ways on my six pack doings. Ray, ive a BB mod man match ported to the bigger felpro gasket you can play with if you dont mess with the ports. Even got a top plate for the mech carbs. This is with the added spacer on mine....so far so good, it ran good with the carbs set back to base line settings, adjusted back to old specs, ran perfect. Only one vid from this install on this A12 car...Seems like they had some bugs to work out....but no more vids then this one.. http://www.youtube.com/watch?v=hAXRJKCuUxo
[Re: Moparnut426]
#1165516
01/27/12 12:01 PM
01/27/12 12:01 PM
sixpackgut
Charleston
Ray, Im just stepping into the fire. Im putting a stock set up on the 440 in the Ramcharger. Basically bone stock, but for a guy like me who can screw up just about anything, a learning curve is gonna hit me like a ton of dominators. Im basically doing it for the "cool" factor, and some performance. To be honest I was planning on contacting you on Facebook for some basic tuneing advice, and if you switch everything up, you might loose your sharpened skills on the multi carb set ups, and I would be lost for ever LOL.
Have you talked with Quick77R/T? He has a mod man with a sixpack on a small block stroker and a lot of extra juice plumbed to it as well.
Kasey
my six pack wont fit on the mod man. the plenum is not long enough. yes, i talk to quick and another guy regularly with six packs on mod man and they both seem to like the intake but they had a stock intake before
[Re: Ari440]
#1165519
01/27/12 03:38 PM
01/27/12 03:38 PM
sixpackgut
Charleston
2 650 avs carbs on my sheetmetal ram
going to dyno the six pack vs the sheetmetal ram and maybe if someone will lend me a single intake i could dyno with a single Dom also
[Re: sixpackgut]
#1165523
01/27/12 09:55 PM
01/27/12 09:55 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I have a team G std port dominator intake I bought from Dwayne you could use on the dyno.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
