Re: i'm bored with the six pack
[Re: sixpackgut]
#1165490
01/26/12 10:37 PM
01/26/12 10:37 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
must be a prison work release program going on in Vermont tonight..even Dwayne pops his head up like a Whack o Mole.....
Just go for it and get it over with....the economy needs you to spend some money.
RIP Monte Smith
[Re: CompWedgeEngines]
#1165491
01/26/12 10:44 PM
01/26/12 10:44 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Dwayne Porter posting on Moparts? holy shiznit, is the world about to collapse or something? oh, and CompWedge, don't worry he already causes me enough pain. Ray, get the mod man and put two thermoquads on it. that'll keep you busy for awhile. when you need help, call doc fibergasass he'll fix you right up with his spiffy back door tool.
machine shop owner and engine builder
[Re: A57_RT ]
#1165492
01/26/12 10:44 PM
01/26/12 10:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
So many look at the mod man as somthing very different, but look at many modern performance intakes over the years in the oem world.
Big plenum/short runner intakes have been around for a while, for example I think the 86 5.0 stangs was the first year for the big plenum 5.0 manifolds.
Since its been brought up, some outside of the mopar world think its good to have a good supply ready on hand, esp on a stroker motor.
There are formulas to detremine how much plenum volume is needed for a motor.
Ive got my carbs 2.5 inches above the plenum area and it seems to like it. And overall better throttle response and ive added plenum volume with the spacers as well.
As what seems to be the only semi cheap option on a small block its a great improvement.
Whats bothersome is one would think indy would do more then just say its new and different, I would think they more then anyone would have some side by side dyno tests.
Mark, you changed your name. an LT1 intake comes to mind when i look at a mod man, i'm not sure about the 5.0 fords, thought they had very long runners
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Performance Only]
#1165493
01/26/12 10:48 PM
01/26/12 10:48 PM
sixpackgut
Charleston
no you scrapped that plan on the phone last night. i have always loved the AVS
[Re: sixpackgut]
#1165496
01/26/12 10:55 PM
01/26/12 10:55 PM
A57_RT
Parts Problem
Parts Problem
[Re: Kevins493]
#1165505
01/27/12 12:41 AM
01/27/12 12:41 AM
Posts: 5,619 long island NY
Ari440
long island NY
indy modman manifold indy bathtub manifold with sixpack top indy tunnelram with sixpack top
1.39 9.85 - 137 mph
