Page 4 of 12 1 2 3 4 5 6 11 12
Re: My '70 'Cuda twin turbo build. [Re: curleysracecars] #1165299
02/28/12 04:31 PM
02/28/12 04:31 PM
CJD AUTOMOTIVE Offline OP
Absolutely awesome build. Excellent work, and its all done the right way. Ive been around fab work, done a lot of fab work, etc. and can appreciate the time invested in this project. Keep it up, and keep the pictures coming.
Thank you! Hope to have more pics soon. Right now, time for the car is weekends only, so progress is slow.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165300
03/01/12 07:05 PM
03/01/12 07:05 PM
Was just looking at the last pics I posted. My painter tells me it's right if you look at it and want to lick it!!! I think it does look like candy, and yes, I have licked it!!
Working on the outside prep. It's all in the details. Will paint the trunk this weekend, and then it goes on the body dolly for outside paint.
The K-frame I built will be back from powder coating next week. Stay tuned!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165301
03/02/12 10:43 AM
03/02/12 10:43 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
AWESOME
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165302
03/08/12 11:18 PM
03/08/12 11:18 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
and the bumper...widened, filed, etc...
still working on fit..
Wow...you are nuts...I LOVE IT. What a great build.
Do you have any progress pics of the bumper? I am in the midst of something similar with the bumper on my 74.
Look forward to seeing your process.
Jason
Re: My '70 'Cuda twin turbo build. [Re: CUDAJAS] #1165303
03/09/12 02:27 AM
03/09/12 02:27 AM
Excellent, excellent work, WOW!
Did you look into the Alterkation unit for a choice possibility? I need to do a custom front suspension on my project.
Robert
Re: My '70 'Cuda twin turbo build. [Re: CUDAJAS] #1165304
03/10/12 10:35 AM
03/10/12 10:35 AM
Jason
Thanks Jason. Yes and no on progress. I finished that bumper and sent it to StarBright Finishes in Oregon. They ruined the bumper and kept my money. I have since built a new one and it is at a reputable chrome shop. I was so mad about that, pictures were the last thing I was thinking about when building a new one. It cost me two bumpers, a set of bumperetts, 25 hours of work, and the money to have them chrome it. Oh yeah, and another set of bumpers, bumperettes, hours, and money to chrome again.
My advice is stick with the two or three reputable platers and forget about trying to save money. In the long run it will cost you more. A lot more.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: ] #1165305
03/10/12 10:42 AM
03/10/12 10:42 AM
Robert
Thanks Robert. I looked at everyones K-frame. The problem with the factory setup is it gains positive camber on compression. All the aftermarket K-frames can minimize the condition and stay neutral, but won't gain negative. The only solution is the XV or build your own. The XV is using C5 Corvette lowers with a short upper. That shortened upper really gains negative when compressed. Almost too much. It was a compromise XV had to make to package in the E and B bodies. I chose to stick with how the factory engineers designed it and move the lower aprons in, allowing me to use stock uppers and lowers.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165306
03/10/12 04:51 PM
03/10/12 04:51 PM
CUDAJAS Offline
CUDAJAS  Offline
Jason
Thanks for the tips. Sucks that you had so much trouble.
I am going to paint my bumpers, to expensive to rechrome them right now!!
Good luck with the build.
Jason
Re: My '70 'Cuda twin turbo build. [Re: CUDAJAS] #1165307
03/20/12 10:59 AM
03/20/12 10:59 AM
Some progress...a little is better than none!!
No, the Viper's not mine, customer car.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165308
03/20/12 12:52 PM
03/20/12 12:52 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
I can't wait to see the motor...
Re: My '70 'Cuda twin turbo build. [Re: JS29R0B] #1165309
03/21/12 11:04 AM
03/21/12 11:04 AM
Me too! Motors done, but switching it to Holley's Dominator EFI. It's only ever ran on a dyno and I'm already upgrading! Sent the intake out for a 16 injector conversion. Should be one of only a handful of R3 engines running DIS and sequential fuel injection.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165310
03/27/12 06:08 PM
03/27/12 06:08 PM
Got the K-frame I built back from powder coating. The lower control arms still need to be done. I painted them after I built them not really sure what I was going to do. That was 4 years ago! Just checking everything to see if it still fits. This stuff hasn't seen each other in awhile...
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165311
03/27/12 06:24 PM
03/27/12 06:24 PM
See, it really does fit an E-body! If you scroll up a few pics, you can see where this fits under the lower frame lip.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Don't forget to add lift points! [Re: CJD AUTOMOTIVE] #1165312
04/18/12 05:00 PM
04/18/12 05:00 PM
Not really an update, but something everyone should do. I've been a tech for 20+ years, which means lifting vehicles everyday, all day. (Vipers suck the worst!) Make sure you add lift points to your ride. You will have to lift it at some point, and I've seen to many "custom" cars get fuel lines crushed, wiring pinched, paint scratched, skirts bent, etc...
This was my solution. I ran the cage through to the bottom of the pinch weld. I welded a nut and washer into the bottom of the tubing. I then made screw in "stand offs" that can be installed to lift the vehicle. This is something that never seems to be important until it comes time to lift the car and you have to monkey with wood, etc.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Don't forget to add lift points! [Re: CJD AUTOMOTIVE] #1165313
04/22/12 10:33 PM
04/22/12 10:33 PM
Mesa , Az
Jambbii Online content
Jambbii  Online Content
Mesa , Az
Craig,
Great idea! I am planning to invest a lot of time detailing the bottom of my car. I guess jacking it up is something you never really think of when building a vehicle.
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Don't forget to add lift points! [Re: Jambbii] #1165314
04/30/12 02:13 PM
04/30/12 02:13 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Any updates?
Re: Don't forget to add lift points! [Re: JS29R0B] #1165315
04/30/12 02:40 PM
04/30/12 02:40 PM
Any updates?
Cars back on the body dolly. Doing the tedious stuff that's not worth posting, i.e prepping under the hood, fitting the spoiler (that I will post, a few tricks going on), etc...Hoping to paint this thing in May.
Doing a few engine tweaks as well. Trying to get it ready and set up for EFI to go back on the dyno. Sold the 67MM turbos and waiting on the 72MM's!!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Don't forget to add lift points! [Re: CJD AUTOMOTIVE] #1165316
05/02/12 10:29 PM
05/02/12 10:29 PM
Santa Rosa CA
Bones Offline
Bones  Offline
Santa Rosa CA
Firs off I want to say that I really love this build. I get so tired of the numbers matching 100 point restorations or straight race cars, it's really nice to see someone with tons of creativity and the skills to match. It would be really killer if you could do a how-to thread with pictures on how to make the jig for the front suspension. I weld and have made jigs for small things but never anything like your Corvette front suspension jig. I know you are really busy with the build and all but if you have some time some day I would really appreciate it and I know a lot of other guys would too.
Do not hug a man holding a wrench in his hand.
Twin Turbo Cuda [Re: Bones] #1165317
05/03/12 10:17 AM
05/03/12 10:17 AM
Thanks for the compliments.
Jigs are easy. Here is one I did for my '37 Plymouth truck.
Set the car at the desired ride height. I knew the overall diameter of the tires I was going to use so I just used wood bucks. This sets the suspension at the proper angles for a given ride height.
Block the body so it will not move. Measure the track width. I get a front and rear measurement from outside brake rotor to outside brake rotor. Remove the suspension components. Build jigs to locate all suspension points. Upper and lower control arms, sway bars, and steering rack. I use washers with a piece of tube inside. Bolt the jig pieces back to the chassis.
It's not necessary to make the wheel turn like I did. I have a fat fender truck, tire width will be critical to turn. If you want to do this, you will need the spindle inclination.
This jig on the front bolts into all the suspension attachments. To get it off the vehicle, it needs to come apart. You can bolt it together like a clamshell, or use DOM tubing that will slide together. I may have to narrow my track width for the truck, so this one slides together. On the 'Cuda, I wanted to keep the geometry exact, so that one used a clamshell bolt together jig. If you use a slide jig, make sure the rack mount locations are on the "fixed" part of the jig. I have the end jigs marked in increments. If I narrow the track width, I move each end in the same amount and will then use a narrower rack. Again, this is a small old truck. This what not necessary on the Cuda.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Twin Turbo Cuda [Re: CJD AUTOMOTIVE] #1165318
05/03/12 10:28 AM
05/03/12 10:28 AM
You can see the jigs have "feet". They sit flat on the floor and locate everything at the proper angles and ride height. The next step is pretty easy. Set the car or truck at your desired ride height. I make wheel flanges on the jigs so I can even bolt on the wheels and tires. You can play with stance by moving the body up, down, or raked. When your happy with the stance, lock down the body. Make sure the jigs are square and start building your suspension mounts from the body to the jig. If it's a frame vehicle, it's pretty straight forward. K-frame cars take a little more work. Bolt rails, tubing, or whatever to the body in the previous K-frame mounts and start building mounts. You'll need to check oil pan to rack clearance. Either one will require custom steering linkage which is readily available.
Let me know if you need any additional info.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
