Re: Dart Gas Tank replacement..
[Re: Cab_Burge]
#1162252
01/23/12 03:03 AM
01/23/12 03:03 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
My '71 Scamp had the 4 tube style tank as shown above. The line that went to the front of the car went to the breather in the valve cover. Since my tank started leaking I'm changing it over completely to the earlier style (already had a new tank I wasn't using) with the earlier filler neck that has the vent in it. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
[Re: MOBodyman]
#1162253
01/24/12 10:03 PM
01/24/12 10:03 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
All four lines go to the vapor tube in the trunk, there is a 5th line coming from the vapor tube that goes up to the 3 inlet breather on the valve cover. My car is a 1/71`production 340 Duster. Also, 2 vent hoses from the tank are 1/4" and 2 are 5/16", so there are 2 different sizes.
[Re: Steve340]
#1162256
01/25/12 10:44 AM
01/25/12 10:44 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
That's what I was talking about! Mark, you want some pics?
[Re: bigblock340power]
#1162257
01/25/12 11:54 AM
01/25/12 11:54 AM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
If you don't mind, that would be great! Seems like a whole lotta plumbing that I can just do away with if I order the other tank ...
