Page 3 of 3 1 2 3
Re: Can't get 340 to idle down [Re: Dodgem] #1161564
01/23/12 07:34 PM
01/23/12 07:34 PM
Forth Worth, TX
Limabean70 Offline OP
Forth Worth, TX
He said he was away on holidays?
thats right, i cant work on it till i get home. just wanted to thank you guys for all your help though.
Re: Can't get 340 to idle down [Re: Secret Chimp] #1161565
01/24/12 01:33 AM
01/24/12 01:33 AM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
Murphy valve in the coolant heater crossover banjo port was sticking and sucking air past the gnome ignitors, I'll bet you money.
Only if he wasn't running the anti-rupture gnome ignitor tips and who does that anymore?
Re: Can't get 340 to idle down [Re: Limabean70] #1161566
01/24/12 10:16 AM
01/24/12 10:16 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's what were here for. remember, the only dumb question is the one you DON'T ask that causes you to destroy your engine or car!
such as this one! had you not asked the question here, and just followed your buddy's advice, you would have pulled the engine out and torn it all down for no reason! but since you asked, you now know that it's all in the "top end" i.e. vacuum leak, timing issue, etc.
**Photobucket sucks**
Re: Can't get 340 to idle down [Re: 70Cuda383] #1161567
01/24/12 10:43 AM
01/24/12 10:43 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The basic engine is a simple air pump, That thing is getting un adjusted air somewhere causing the idle to stay high. Also causing a lean condition most likely. All the carburetor is is an air fuel metering device. and the intake dispurses that air fuel mix evenly through out the engine, any air entering the engine in any other way is a LEAK, and causing a high idle, unless you have the timming all jacked up.
More than likely an air leak.
Which has already been stated.
Re: Can't get 340 to idle down [Re: Moparnut426] #1161568
01/24/12 12:25 PM
01/24/12 12:25 PM
scratchnfotraction Offline
I have had a stuck pcv valve do this,and have had a brake booster check valve/gromet do this.
I have also had the small 318 port size tin gaskets leake with a 360 port size intake,from under the intake,burning oil/smoke showed up right away.
had a carb not torqued down give fits for a couple days,went to R&R it and found the nuts loose
I wager vac leak but I have also had to reset carb settings/adjustments when swaping from engine to engine.
get a vac gauge and timeing light on it and check for leaks
Page 3 of 3 1 2 3
