Re: Subframe connector options and opinions
[Re: RTSE4ME]
#1161229
02/11/12 11:13 AM
02/11/12 11:13 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
They also welded the top of the cage to the roof. Never saw that before.
I've done that before on my street stock cars. There are classes that outlaw that as well because the the advantage it provides. SCCA and NASA have some that come to mind.
[Re: radar]
#1161231
02/12/12 11:40 AM
02/12/12 11:40 AM
Posts: 2,470 Answering the call of the wild
ThermoQuad
I did a ton of seam welding on project Charger blacknblue as well as adding the subframe connectors and the "rust repair boxes" to the front frame rails where the torsion bars live.
Some one out there welded up an a body and it worked!
Cop cars got 120 extra welds it's in the cop car brochures Aspen/volare/M body cop cars got gussets as well
[Re: Kern Dog]
#1161233
02/13/12 06:25 PM
02/13/12 06:25 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Heres a pic of thre xv connectors... I wasn't impressed with the fit at all, they took a ton of grinding to fit. I did smooth them out with some polyester, but afterall the work they did turn out nice. After installing these, my challenger will get some square tube and cut into the floors.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Kern Dog]
#1161235
02/14/12 10:28 PM
02/14/12 10:28 PM
Posts: 186 Middleton, ID
curleysracecars
Middleton, ID
Franken...its all in the setup of the machine. You dont want much spatter or slag...you want the weld material sticking to your base material. I know it sounds obvious, but this is MUCH more critical when doing overhead stuff. I HATE it, but only because I dont like the sparks landing on me...I can still weld pretty nice. Where in GB are you again? Maybe I can come by...it would be nice to meet someone from the forum anyways.
Kyle Curley
[Re: Kern Dog]
#1161238
02/15/12 12:58 PM
02/15/12 12:58 PM
Posts: 22,738 Bitopia
jcc
Bitopia
Yes any welding supply should have it, its also more properly called Nozzle dip. I think the problem you are having is multifold, dirty hard to clean welds, and the toughness of welding thick to thin, overhead, out of position is just not easy, skill/practice helps, but its still tough.
[Re: jcc]
#1161239
02/15/12 01:20 PM
02/15/12 01:20 PM
curleysracecars
Middleton, ID
Franken, I use Nozzle spray...I dont like the dip because it drips out of the end of the nozzle when you pull it out of the "tub" it comes in. I use a spray. I spray the material and the nozzle on the gun. As you mentioned, welding on old, dissimilar metals is probably your biggest problem. There is so much crap imbedded in old material, even though it looks clean, it is still usually contaminated to some degree.
Kyle Curley
[Re: 74DUSTER360]
#1161243
04/27/12 12:47 AM
04/27/12 12:47 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Check out these bolt in frame connectors - http://unlawfulracing.com/FrameConnectorKits.html
Those look pretty cool. It appears like the rear legs actually fit into the front spring hanger bolts. Obviously this wouldn't work if you had torque boxes, but this setup looks impressive.
[Re: 74DUSTER360]
#1161244
04/27/12 04:58 AM
04/27/12 04:58 AM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
US Car tool and Auto rust techs torque boxes being installed on Sinnamon. I have MP's on Black Betty... they were good for the day. Had and returned XV sfc's.... they didn't fit at all.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: TC@HP2]
#1161247
05/29/12 01:06 AM
05/29/12 01:06 AM
Posts: 4,848 Memphis
HemiRick
Memphis
However, the rocker panels aren't thick gauge steel.
Here you are wrong, on my 70 Challenger the rocker metal is much thicker than the rest of the sheet metal. I know because my rocker had a big dent and I cut out that section to put in a replacement patch. The patch was regular sheet metal thickness and I ended up beating my original section straight and welding it back in.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
