Page 5 of 5 1 2 3 4 5
Re: Subframe connector options and opinions [Re: dangina] #1161248
06/04/12 01:30 AM
06/04/12 01:30 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Brads70 from protouring mopar offered this idea from his ride which I'll be doing myself - its 1x2" 0.90 tubing with tubes added for strength:
I've been staring at this picture and drooling, but I lack the equipment to replicate them. But I got to thinking, what if you took 2 pieces of 1"x1" tubing and welded them full length side by side to create 1"x2" tubing with a double thickness wall down the center. Would that be just as strong? Since most tubing has slightly rounded corners there would be a natural "groove" that would lend itself to a very solid weld. Any thoughts?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Subframe connector options and opinions [Re: MadMatt] #1161249
06/04/12 03:27 AM
06/04/12 03:27 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
While I agree that those 1x3" units with the holes look really cool, I doubt that they have as much strength as a 2x3 or a 2x2. MUCH of the strength is in the vertical plane, and a 1x3 only has 1 inch there. Most agree though that any support added there is a benefit.
Re: Subframe connector options and opinions [Re: Kern Dog] #1161250
06/05/12 11:49 AM
06/05/12 11:49 AM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
I used ART for the boxes and frame connectors for my 68 B Body. No problems and they make a difference. Here they are before paint...
Re: Subframe connector options and opinions [Re: 68 Sat] #1161251
06/05/12 11:55 AM
06/05/12 11:55 AM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
the money pit
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
