Re: Subframe connector options and opinions
#1161213
01/22/12 12:48 PM
01/22/12 12:48 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Aren't the factory rockers in effect thick gauge sorta-square tubes connecting the front and rear subframes? If so, what do aftermarket subrame connectors do that they don't? Just add strength to the connection because you now have four subrame connectors instead of two? Perform some other function? <snip!>
I thought the same for decades. The I started to notice that newer Mopars -- every B-van, Cherokee, Neon, Stratus, etc. had what was effectively "frame connectors" from the factory, which they started referring to as "uniframe" design. So I give some simple 2X2" tubing a shot (A-body). Holy cow, the first block, I was fairly well freaked out. The difference in platform rigidity was instantly noticeable.
2X3" (slit the floor) is obviously even better.
The sawtooth ones are surely a cleaner installation, but are only as strong as the narrowest point.
Take your pick. But do something! You'll never look back!
Rick E.
[Re: kielbasa]
#1161216
01/22/12 10:00 PM
01/22/12 10:00 PM
Posts: 27,486 So Cal
autoxcuda
So Cal
I myself would love to do something, but what options exist for those of us that those of us (for fear of ruining the cars value) have a hard time with cutting into our cars? I'd love to stiffen up my AAR, but cringe about welding into it.
The Hotchkis ones bolt to the leaf spring pickup point where the rear tire load is transmitted. But check if they work with factory leaf spring boxes (AAR/Hemi/conv/etc)
At the front the Hotchkis connectors weld to the trans crossover. To remove, I think someone can cut the welds, dress the remaining material and even a little bondo and it will be unnoticable. If your car is full undercoasting that would be easy to hide.
[Re: autoxcuda]
#1161217
01/23/12 02:02 AM
01/23/12 02:02 AM
Posts: 2,065 MD
RTSE4ME
MD
Would the Hotctkis connectors clear the side exhaust?
[Re: kielbasa]
#1161218
01/23/12 11:02 AM
01/23/12 11:02 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Honestly, in your case I wouldn't worry about it unless you are modifying it for other off-road activities. The e-bodies are already pretty decent. Mitch Lelito's ran very well in National level Solo2 with no connectors in his Challenger. It's also worth noting that for anyone considering running in E Street Prepared (ESP), the connectors can not come through the floor, nor may they be continuously attached to the floor.
My experience with the DC/MP connectors welded front and back (but no other attaching points) is that they do not add alot of stiffness. They are too shallow and really need additional attachment points. A short brace bolted to the rocker to floor brace is a possible answer for those who wish run in ESP or SM. As several posters have already said or implied, the more hieght in the cross section and more attachment points, the more effective the connectors will be. Two inch height in the cross section is a minimum to make them worth anything.
[Re: domingo]
#1161220
01/25/12 07:42 PM
01/25/12 07:42 PM
Posts: 489 NE
bigtail
NE
So, when will be ready to ship? Will you have a tube welded in for the e-brake cable? Will resto ricks carry them? How much? I would buy sub frame connectors and torque boxes as well. Would you offer them as a kit? I have an xv radiator support yoke I will be adding as well. And I plan on a firm feel welded k frame, and poly bushings. c body tie rod ends, welded LCA plates. I want my Challenger SOLID! Please let us know when your connectors are ready, Domingo!
This page is made up completely of recycled electrons.
[Re: Valiant_Showoff]
#1161223
02/02/12 03:54 PM
02/02/12 03:54 PM
Posts: 22,810 Bitopia
jcc
Bitopia
Some of the info you seek might be found on chassis mod thread at the top, and compile you your own answer. Sorry I haven't register on my own thread ![](/ubbthreads/images/graemlins/bow.gif) . I installed a 2x2x.083 not cutting the floors on an early b body, and with combination, noticed little change. Others have much better results, I think as mention earlier in this and other like threads, increased section width/height is much more important to see positive results then greater wall thickness, ie .083 is a good compromise IMO.
[Re: Mattax]
#1161224
02/02/12 04:26 PM
02/02/12 04:26 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Well said, Matt... SCCA E/Street Prepared rules do not allow cutting of the floor or full-welding to the floor, etc. Only recently a few years ago did they start to allow the front and rear to be welded... prior, they had to be bolted only. Maybe I'll put in the Hotchkiss eventually, or those CPA(?) round/dual ones? Ground clearance is an issue for me, as well. Ultimately, I don't just want to add weight if they won't give a truly good improvement. Chyrsler built their unibody cars very well back then, in my opinion.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Rick_Ehrenberg]
#1161226
02/11/12 12:15 AM
02/11/12 12:15 AM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
This is long, read at our own risk. Quote:
The first question should be IMO, could someone describe and BACK UP at least, with sound reasoning, what actual forces sub frame connectors resist? I am not questioning many many positive reports of their improvements in ride etc. So are they resisting compression as the rear leafs push forward upon acceleration, are they resisting twist individually, if just under tension we can just use a steel cable, are they preventing a bending moment as front of leaf pushes up upon acceleration with a bending moment provided by the front mass of the car, i.e. engine, etc, are they just straightening out the force path thru 4 right? angle turns from the front hanger to the doorsills back to the TB cross member, etc?.
If we knew what they are resisting, it would be a lot easier to design a solution. I suspect they are doing all the above, but some more than others, but which one? Say if twist was the main force, a large dia tube would be first choice, if bending moment, a tall I beam, yaw? bending, an I beam on its side, etc. My understanding is it needs to be the smallest and lightest shape/size that gets the job done. Anyone can oversize a solution, only a smart designer knows just how much is needed, if you way oversize, you look.....?
Years back member AAR? (patent attorney) had a lengthy thread on Sub-frame connectors, and main conclusion was the larger the crossection of the sub-frame, the stiffer, wall thickness provides a lot less stiffness then crossection increase gives. The installation advantages are numerous with the contour cut-out connectors, and installation ease IMO is their only advantage. Performance wise, compared to a full tube they leave a lot on the table.
Once again, JCC performing the sanity check.
Going back to the muscle car era, from which most of our favorite rides have been derived, the predominate activity involving our automobiles was drag racing. Reading through the literature derived from the era, Mother Mopar, with support of her engineering staff, developed sub-frame connectors to support a car against high powered drag launches and to aid the stock uni-body against axial flexure. It seems 500 horses, drag slicks, a prepared surface, and high rpm launches would conspire over a period of time to bend a car in half. The super stiff front segment of SS spring packs would push up on the passenger compartment floors while pulling down on the shackle mounts. Since the only things holding the middle of the car intact are the door sills, roof, and floor plate, sub-frame connectors were developed to keep roof/quarter seams from splitting, quarter panels form buckling, and back lights from popping out.
In light of that activity, the best connector would be tall, probably bisecting the floor, and provide a great amount of bending resistance against the launch. Think of the floor joists in a house. They are stood on edge to resist deflectionand support weight. Drag race connectors should do the same thing. Of course, anything is better than nothing and even wide 1x2 connectors help out, as do contoured weld in connectors. Obviously 2x3, 3x3, or even 3x1 are better. Using the old bumper jack and open the door test, a simple before and after test will show improvements with the most basic of bolt in connectors installed. Are they optimal, no, but they are better than nothing. But we aren't talking just drag racing since we have this new forum to play in and we need to consider alternate applications. Looking at research done by XV, DSE, Herb Adams, Julian's, Nascar and others, sub-frame connectors alone don't do a whole lot to increase torsional rigidity. Think of a ladder, there are very strong side rails and lots of cross members, but you can still twist it. So you need to think three dimensionally.
Which segues us into this;
Aren't the factory rockers in effect thick gauge sorta-square tubes connecting the front and rear sub-frames? If so, what do aftermarket sub-frame connectors do that they don't? Just add strength to the connection because you now have four sub-frame connectors instead of two? Perform some other function?
<snip!>
I thought the same for decades. The I started to notice that newer Mopars -- every B-van, Cherokee, Neon, Stratus, etc. had what was effectively "frame connectors" from the factory, which they started referring to as "uni-frame" design. So I give some simple 2X2" tubing a shot (A-body). Holy cow, the first block, I was fairly well freaked out. The difference in platform rigidity was instantly noticeable. Rick E.
Actually, yes, you're are somewhat correct in your assumption. However, the rocker panels aren't thick gauge steel. They are the same flimsy stuff that the rest of the body panels are made of. Again, Mother Mopar's research in to this confirmed this and when the Kit car program was developed, the door sills were a dominate structural fixture. However, the also suggested gutting out the inside (floorboard area) and adding square tube bracing to it before tying it in with other structural components. The methods they suggested in this tie in were all bisecting angles that created a car full of triangles. In nature, the strongest inherent shape she has developed is a circle, or sphere. Since cars aren't made with spheres but rather intersecting lines, the next strongest shape, that is compatible with auto design, are triangles. To create rigidity in a car, you need to fill it with triangles. If you look at a traditional sub frame connector, they creates three rectangles out of the cars floor. Rectangles can bend and diamond out of shape. By contrast, triangles resist deformation. Additionally, as a car goes through a corner, it transfers weight diagonally and laterally. Again, triangles assist by providing rigidity where needed while transferring weight were necessary. Obviously this works much better if you think three dimensionally and start creating triangles through-out the car, much like what a current Nascar Cup car looks like. But not all of want to have a street car that looks like a race car. So we compromise and add them in select places without getting to intrusive. If you have ever viewed XV's before and after video of their chassis stiffening it, you'd be amazed what 5 simple pieces of steel can do to a cars foundation.
A big part of why sub-frame connectors works so well is because our cars are put together with spot welds. On top of that, our cars are old, which means those spot welds have had years of flex working against them as well as decades of elements attacking their structural integrity. Consider this, your clothes are stitched together to tighten up seams, close gaps, and provide a better fit. By contrast, our cars are like clothes that are held together with snaps or buttons. Sure they are all together, but they allow gaps and flex. Stitch your car together, just like your clothes, and you eliminate the flexure the requires sub frames to begin with. Julian's did this research on a 1st gen Mustang and through simple rocker sill reinforcement, seam welding, and select bracing, they were able to firm up the Mustang uni-body 70% over stock without installing additional sub frame connectors. SCCA has not allowed seam welding in all stock level competitors because it provides an unfair advantage in structural rigidity. They have only recently relented and allowed sub-frame connectors at all.
A couple of places to read a more in depth analysis of it can be found here:
http://www.pro-touring.com/showthread.ph...;highlight=sn65
http://sn65.com/Chassis%20Design%20101.htm
