Rod knock at idle only???
#1159400
01/17/12 03:53 PM
01/17/12 03:53 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
First let me give a rundown. My freshly rebuilt Magnum 318 is cursed. Standard rebuild parts replaced, rings, bearings, oil pump, timing set. When I first fired it up, there was a coolant leak at the rear of the intake that was contaminating the oil. Fixed that. Next, the oil pump locked up. Replaced it with a standard volume pump. Then I lost two lobes on the flat tappet cam that was in there, so I put the stock roller back in it. Now I have what sounds to be a bottom end knock at idle only. When built, I measured bearing clearance at .0015" on the rods, and .0015 on the mains. The original bearings looked great when removed. I'm running the same trans, converter and flexplate as the before. It only knocks under 1,000rpm. It has a little knock that's more pronounced at startup, but as it warms up, there's a steady "thump thump thump" that has the repetition of an exhaust leak, which leads me to believe its on one cylinder only. But 90% of the time its there, with no noise on decel, and no noise revving it up or at steady cruise. There is also a vibration above 3,500 or so. I'm am running a neutral balance converter though. Is it possible to have a rod bearing on its way out as a result of the oil pump locking up? When it happened, I had to idle for roughly 1/2 mile or so to get it out if harms way. But it runs great other than that. Any ideas??? It's not a big deal to drop the pan, but I figured I'd get some input from the masters first
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Rod knock at idle only???
[Re: WO23Coronet]
#1159404
01/17/12 10:48 PM
01/17/12 10:48 PM
RapidRobert
As said pull the pan & go from there & hopefully R&R the bearings will restore it but I'm not optomistic on this one
[Re: RapidRobert]
#1159405
01/17/12 10:59 PM
01/17/12 10:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I had a chunk of casting flash break loose and get sucked up into the pump of my 360. Lost oil pressure and drove it home for probably 3 miles. New pump and pick up and I was good to go. I don't think a 1/2 mile drive would have wiped the bearings. Maybe some junk from the wiped cam made it past the pump and wiped the bearings?
[Re: 69L78Nova]
#1159407
01/18/12 01:17 AM
01/18/12 01:17 AM
Posts: 7 Sorrento, Florida. USA
scs2bbdak
Before you pull it apart, try cranking it up and pull one plugwire off at a time. The knock should get a lot worse on the dead cyl. At least you'll know where to start. If they're tough to get at and get off the plug, do it when the engine's cold and one start at a time, until you find it. Chances are you wiped a rod bearing, but maybe a main too. Best of luck guy.
bye bye, buy Dodge!
[Re: BigTerry]
#1159409
01/18/12 02:49 AM
01/18/12 02:49 AM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
have you cut open the oil filter yet ?
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: draginmopars]
#1159410
01/18/12 09:07 AM
01/18/12 09:07 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I haven't cut the filter open but the pan is coming off tonight. The knock is barely audible. You actually have to try to listen for it. It's not something that is just banging away. I just happen to notice it. Hopefully as said, there is no damage to the crank/rod
[Re: scs2bbdak]
#1159412
01/18/12 11:32 AM
01/18/12 11:32 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well I'm going to pull the pan first. It didn't start making the noise until the oil pump incident
[Re: 69L78Nova]
#1159413
01/18/12 11:42 AM
01/18/12 11:42 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Take no chances and pull it apart (again!), you will find something wrong for sure.......
If you remove the pan AND oil pump, take the pump apart to see if chunks might have gone trough it, there will be visible marks inside
.015 is too tight, shoot for .020-.025 Dan
[Re: 69L78Nova]
#1159414
01/18/12 11:44 AM
01/18/12 11:44 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
The pump incident is more than likely related to the camshaft lobes going flat , all that metal goes thru the pump before getting to the filter. This is why when you eat lobes off a cam you need to pull the engine out and apart , the piston skirts under the flat lobes can get pretty scarred up also .
[Re: 69L78Nova]
#1159416
01/18/12 11:00 PM
01/18/12 11:00 PM
Posts: 2,782 USA
JoesMopar
USA
Before you pull anything off the engine, check to make sure the flex plate bolts are still tight. I had this happen a few times on a 440 and swore it was a rod knocking or something. Same as with you, it was more profound at idle and seemed to "go away" when reved.
Well I guess I should read these things the whole way through before I post. Nevermind then if you already found the problem.
[Re: 69L78Nova]
#1159417
01/18/12 11:04 PM
01/18/12 11:04 PM
Supercuda
About to go away
About to go away
up yours
One has to ask, how did it get past the filter? I hope you are changing that too.
[Re: Supercuda]
#1159418
01/18/12 11:34 PM
01/18/12 11:34 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Absolutely. Oil and filter every time. I'm just surprised the crank looks unscathed. I'm just glad I caught it when I did.
