Oil pressure readings during a 1/4 mile pass
#1159373
01/17/12 02:28 PM
01/17/12 02:28 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Now that we have more and more technology at our finger tips we can monitor our engines better than ever during a pass and I know its raising some questions, at least for me it is. First off I was never the guy that could tell you oil pressure, water temp, trans temp, fuel press, O2 readings,and rpm like some guys claim they can. I added a racepak system and I see my oil pressure is really spiking during a run and would like to know what you guys are seeing. I will start out by saying I have 60# of pressure at warm idle and around pits. I will post my pressure during a run after a few posts later in the day. Here are some engine specs. Sorry about the long post. 408 engine with W2 heads. 540 lift solid cam oil system modified as per old Direct Connection manual. I tubed oil galley and installed plug going to other lifter galley and redrilled all passages to recommended size. (.283) VR1 20-50 oil with Zinc additive Wix racing filter. HV oil pump with Milidon 8 quart oil pan. .0025 main bearing clearance. .0025-.0027 rod bearing clearance This engine has about 12 passes on it the oil looks great and ran a 9.98 in the duster last time out. Thanks for any info.
Re: Oil pressure readings during a 1/4 mile pass
[Re: pittsburghracer]
#1159374
01/17/12 02:43 PM
01/17/12 02:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
During the run its 80#.... a combo of 20w-40 and 10w30 to set my oil pressure when hot EDIT this is on a dry sump turning 8200 rpm
[Re: jamesc]
#1159376
01/17/12 05:34 PM
01/17/12 05:34 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I leave on the brake at 4800 and the pressure jumps from 60# to 120# from the the starting line till I leave up at the end of the 1/4 mile. This is the first small block that I have done this modification since the 70's. I plan on switching to Brad Penn oil this year and with try 10-30 weight instead of VR1 20-50 but it will probably still be reading pretty high. I wonder what a standard oil pump would do instead of the high volume?
#1159382
01/17/12 09:06 PM
01/17/12 09:06 PM
Posts: 30,464 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
120 psi ? ... not only is that uNsane ...it is the PITTS !
[Re: tboomer]
#1159386
01/17/12 09:39 PM
01/17/12 09:39 PM
dOc !
Florida STAYcation
The filters may have that burst stength but the o-rings don't!! And yes....I got an expensive jacket from Summit!
Wasn't there a moparts member that blew-out an o-ring or line ...oil their tires and then WRECKED their car ?
[Re: 440Jim]
#1159388
01/17/12 10:06 PM
01/17/12 10:06 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Jim i'd say all those number are pretty much what i'm used to seeing. not so funny story one of the last times i had the car out this season my oil light got me cause it's set so high. i'm used to seeing it flicker idling down the return road but we were running round robin at the end of the night so the oil was thinning out. i stage the car in the final round (staged last) and it blinked on and distracted me, i regained my composure but then it blinked again...that was it missed the tree. stupid light cost me the final round and $300 i said to myself "that won't happen again" and tried to set it lower when i got home but the pressure switch i'm using won't really go below 40#, i need to get a different switch.
