Re: 1969 Hemi Coronet R/T restoration
[Re: 69x]
#1159212
01/22/12 04:24 AM
01/22/12 04:24 AM
Posts: 1,187 USA
big-block-dave
USA
So is my T5 4 speed worth more in black than T5?
Not to me because color changes are a turn off
I agree with the above. When i see any A,B,E, even C body cars in rare colors such as A4, X9, FM3, i say to myself, wow that's rare lets go check it out. FIRST thing i check is the fender tag, if it's a color change from original, even if it's a rare color to another rare color, it's still a turn off to me. Kinda DEFLATES my excitement for that car!...........My 2nd vote, keep it A4, stripe delete with the R/T emblems is really COOL!
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: 69x]
#1159217
01/22/12 08:35 PM
01/22/12 08:35 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Build the car like you want.. The thought of somebody spotting a gorgeous triple black Hemi Bee from across the feild mouth watering each step they get closer to it, adrenalin rushing in through their veins as the look the car over. It's mint and i mean perfect. The detail is second to none, but wait as he looks over the fender the tag says it ain't a real black car. This thing sucks and he walks away like he was just rapped... LoL this would have been my dream car, damn...
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: gregsrt]
#1159221
01/24/12 08:51 PM
01/24/12 08:51 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
nice project. I am also a 69 Coronet R/T fan. they are a bit rare. do it how you want! it will be great any color. I will enjoy this thread.
HEMI,S ARE FOREVER!!!
[Re: drmopar]
#1159224
04/28/12 12:08 AM
04/28/12 12:08 AM
Yep, not much progress to post on bodywork. I have been pretty busy with work and house projects recently too like remodeling the entire bathroom . I have finished up the rear axle and springs are almost done too.
The axle housing is a super minty 8 3/4 piece from a low mile 69 Charger. I had the housing hot tanked, bead blasted and powder coated 30% gloss black. I had DTS build the 489 center section from scratch for me. I gave them the case cleaned and finished in an epoxy cast paint. All in all it is a pretty stout piece with a Detroit trutrack differential, Strange 430 ring an pinion, crush sleeve eliminator and a 7290 yoke from Mancini racing. The axles are Strange 30 spline units with non adjustable green bearings. The backing plates a re N.O.S pieces courtesy of Rich Ehrenberg. All brake shoes and hardware are NAPA parts. I got lucky with the e brake levers, I found them in a parts bin of stuff I removed from my old 69 R/T droptop 4 years ago. The e brake cables, brake lines, brake tee, vent bolt and hose are all from Inline tube. The lines took a little to get right, but the fit ok now. I located a new set of 11 x 2.5 drums to put on as well. I took some liberties with the assembly line art work, but I think it looks pretty good.
Next is the front steering and suspension. I have the K frame powder coated as well and I have been slowly aquiring pieces here and there. First things first though, sod and more sod for the front yard
Here is a few pictures of the axle buttoned up.
[Re: ]
#1159225
04/28/12 12:09 AM
04/28/12 12:09 AM
[Re: 1969MCODE]
#1159227
04/28/12 01:22 AM
04/28/12 01:22 AM
I still think you should have kept the B5 A12 4-spd Bee , but that RT will look AWESOME when finished! Keep the pics coming as the work progresses.
I would have kept that one and my old r/t droptop if I could have, trust me.
Im glad you sold it mate, dont worry its in good hands
Stop it Andrew!
[Re: easygoingjuan]
#1159230
06/25/12 05:48 PM
06/25/12 05:48 PM
Heading to the body shop wednesday to see some updates. I will take some pictures then. Supposedly the floor pans are in and the trunk floor is on its way out. Veeeerrrrrryyyyyy slow go on the body work right now. The parts keep coming in though, the UPS driver knows me well
