Page 5 of 5 1 2 3 4 5
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157955
04/16/12 01:23 AM
04/16/12 01:23 AM
An Island in the Pacific N.W.
moopa Offline OP
moopa  Offline OP
Using the following blasting equipment: homemade pressure blaster, confined space blower,uses 12" accordion style vent tube, and finally, a fresh air breathing unit...it's such a dirty messy job...but at least I'm doing it at home and not having to pay someone else to do it.
Mark [image][/image] [image][/image]
2015 TorRed Challenger Hellcat,A8 2013 Plum Crazy Challenger SRT8,6 Spd 2013 Black Challenger R/T Classic,auto (2)72 Satellites, one on hold,one under resto on the rotisserie.
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157956
09/19/12 02:52 AM
09/19/12 02:52 AM
moopa Offline OP
moopa  Offline OP
A ha! Stalled but not forgotten. Here's the new rotisserie, with the Satellite mounted and ready for even more good things to come!
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157957
09/19/12 02:56 AM
09/19/12 02:56 AM
moopa Offline OP
moopa  Offline OP
Now to photograph all the underside stuff before I get started.
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157958
09/19/12 08:45 PM
09/19/12 08:45 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
Looking good !
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: New Project 1972 Satellite Part 2 [Re: 71DemonRON] #1157959
09/20/12 10:51 PM
09/20/12 10:51 PM
moopa Offline OP
moopa  Offline OP
Thanks Ron! Any luck selling your beast?
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157960
09/20/12 10:59 PM
09/20/12 10:59 PM
moopa Offline OP
moopa  Offline OP
I want to make sure I know where all the little brackets for fuel and brake lines go, before I remove all of them! [image]http://[/image] [image]http://[/image]
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157961
09/20/12 11:10 PM
09/20/12 11:10 PM
moopa Offline OP
moopa  Offline OP
I was searching for photos of brackets used to mount a 71-72 Plymouth B Body to a rotisserie, but didn't see any I liked. The rotisserie manufacturer suggest using the single bolt hole mounts....and it made me queezy, so I came up with these front mounts that use the front bumper bracket bolt holes.( the factory single hole mount brackets slide through the brackets I made out of 3" angle iron and 2 1/2" square tubing. Due to to offset of the bumper bolt holes, I needed to weld a piece of 1/4" flat bar to the angle iron.) They are very stable, and with the set bolts, I can slide the brackets to get the front rotisserie assembly as close as I want it. [image]http://[/image] [image]http://[/image]
Then for the rear I fabbed up some stout brackets that mount to the rear spring mount. Even though its only mounted with one bolt, I added some 2"x 1/4" square tubing between the frame and bracket to prevent pivoting. [image]http://[/image] [image]http://[/image]
Re: New Project 1972 Satellite Part 2 [Re: moopa] #1157962
11/24/12 01:16 AM
11/24/12 01:16 AM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
Looking good
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
